Roller Shutter GUI on Dashboard (Up-Half..-STOP-Half...-Down)
I've searched through all the topics but did not find any roller shutter (= blind) Dashboard Widget.
The only thing I've found is this:
But that one does not seems to be "pushable" to control this way:
  • UP (full)
  • Up 50%
  • STOP -
  • Down 50%
  • DOWN
Is it possible I've missed something like this on a dashboard?
kép
There are thousands of NR users around the globe and 70% of us using it for home-automatisation.
It just seems for me impossible nobody ever needed a thing like that?
Not sure what you are asking - Have you tried sending a payload ?
msg.payload can be 0 to 100 (100 = 100% opened)
If this is not what you want you could look at this thread also - Dashboard tips. Let the ui_text act as level gauge ... DIY gauge examples
As smcgann99 said, you can set every position with this shutter template (its from me). See Screenshot 1.
a) (Screenshot 2)
I have multipe buttons => MQTT Out Node (Set Position)
e.g. Button 1, Payload 100
to MQTT Out Node, Topic "shellies/wz-rollade-1/roller/0/command/pos"
b) (Screenshot 3)
MQTT In Node => Shutter Template (Show Position)
e.g. Topic "shellies/wz-rollade-1/roller/0/pos" to Shutter Template
Bildschirmfoto 2022-03-27 um 19.57.54
Bildschirmfoto 2022-03-27 um 19.57.59
Thank your for the detailed post! :slight_smile:
So I was right: That nice widget is only able to SHOW a status, not to control anything.
I'm more interested at those 3 blue buttons [^] [stop] [v].
Is it possible to create 5 of them as a template and use it 8x for all roller shutters?
(I don't think that placing 40 buttons one by one is an ideal solution.)
Here's my roller door simulation - which is part of the flow I used to control my garage door via Alexa.
In the function node I use a counter that increments from 0 to 100 or decrements from 100 to 0.
Screen Shot 03-27-22 at 08.24 PM
You might be able to modify it to suit your needs.
[{"id":"a47754ee.cc9948","type":"ui_template","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","group":"273505a6.34ddaa","name":"Roller door simulation","order":1,"width":"0","height":"0","format":"<style>\n        :root {\n            --rollade-color: #097479;\n            --rollade-width: 90px;\n        }\n        .rollade__container {\n            width: var(--rollade-width);\n            overflow: hidden;\n            position: relative;\n        }\n        .rollade__fenster {\n            position: relative;\n            overflow: hidden;\n            z-index: 1;\n        }\n        .rollade__fenster path {\n            stroke: var(--rollade-color);\n            fill:none!important;\n            stroke-width:6px;\n        }\n        .rollade__rollade {\n            position: absolute;\n            width: 100%;\n            height: 100%;\n            left: 0px;\n            z-index: 10;\n            transition: all 1s;\n        }\n        .rollade__rollade path.line {\n            stroke: white;\n            fill: none;\n            stroke-width: 1.5px;\n        }\n        .rollade__rollade path.bg {\n            fill: var(--rollade-color);\n        }\n        \n    </style>\n\n    <h3>Door position</h3>\n    <div class=\"rollade__container\">\n        <svg class=\"rollade__fenster\" width=\"100%\" height=\"100%\" viewBox=\"0 0 170 188\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" xml:space=\"preserve\" xmlns:serif=\"http://www.serif.com/\" style=\"fill-rule:evenodd;clip-rule:evenodd;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:1.5;\">\n            <g transform=\"matrix(1,0,0,1,-15.909,-45.6212)\">\n                <g transform=\"matrix(0.989904,0,0,0.992491,4.03539,0.837446)\">\n                    <path d=\"M180.329,56.389C180.329,51.839 176.626,48.145 172.064,48.145L23.291,48.145C18.729,48.145 15.025,51.839 15.025,56.389L15.025,222.454C15.025,227.004 18.729,230.698 23.291,230.698L172.064,230.698C176.626,230.698 180.329,227.004 180.329,222.454L180.329,56.389Z\" />\n                </g>\n                <g transform=\"matrix(1,0,0,1.38253,3.04599,-37.9811)\">\n                    <path d=\"M97.589,64.432L97.589,191.286\" />\n                </g>\n                <g transform=\"matrix(1,0,0,1,2.84135,56.1777)\">\n                    <path d=\"M18.74,83.189L177.463,84.189\" />\n                </g>\n            </g>\n        </svg>\n        <svg class=\"rollade__rollade\" style=\"top: calc((-1) * {{msg.payload}}%);\" width=\"100%\" height=\"100%\" viewBox=\"0 0 181 190\" version=\"1.1\" xmlns=\"http://www.w3.org/2000/svg\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" xml:space=\"preserve\" xmlns:serif=\"http://www.serif.com/\" style=\"fill-rule:evenodd;clip-rule:evenodd;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:1.5;\">\n            <g transform=\"matrix(1.35281,0,0,1.35281,-45.3041,-102.109)\">\n                <path class=\"bg\" d=\"M167.134,82.161C167.134,78.473 164.14,75.479 160.452,75.479L40.171,75.479C36.483,75.479 33.489,78.473 33.489,82.161L33.489,208.93C33.489,212.618 36.483,215.612 40.171,215.612L160.452,215.612C164.14,215.612 167.134,212.618 167.134,208.93L167.134,82.161Z\"/>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,-9)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,1)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,11)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,21)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,31)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,41)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,51)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,61)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,71)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,81)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,91)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,101)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n                <g transform=\"matrix(1.69574,0,0,1,18.3547,111)\">\n                    <path class=\"line\" d=\"M13.383,95.652L84.46,95.652\" />\n                </g>\n            </g>\n        </svg>\n    </div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","className":"","x":1460,"y":200,"wires":[[]]},{"id":"8c54390f2bb17c9b","type":"inject","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payloadType":"date","x":1030,"y":140,"wires":[["bb3c87874a48df16"]]},{"id":"bb3c87874a48df16","type":"trigger","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"250","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1040,"y":200,"wires":[["c77fdce872c5e850","2c9ca19a07baabd2"]]},{"id":"c77fdce872c5e850","type":"debug","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1250,"y":260,"wires":[]},{"id":"6441625a23250da7","type":"link out","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"","mode":"link","links":["825f1f9b12488582"],"x":995,"y":280,"wires":[]},{"id":"825f1f9b12488582","type":"link in","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"","links":["6441625a23250da7"],"x":1095,"y":280,"wires":[["bb3c87874a48df16"]]},{"id":"2c9ca19a07baabd2","type":"function","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"","func":"var roller_pos = flow.get(\"roller_pos\");\n\nvar state_register = flow.get(\"state_register\") || \"S0\";\n\nif (state_register == \"S0\") {\n    flow.set(\"roller_pos\",0);\n    node.send( [{payload: 0}] );\n}\nelse if (state_register == \"S1\") {\n    if (roller_pos < 100){\n        roller_pos++;\n        flow.set(\"roller_pos\", roller_pos);\n    }\n    node.send( [{payload: roller_pos}] );\n}\n\nelse if (state_register == \"S2\") {\n    flow.set(\"roller_pos\", 100);\n    node.send( [{payload: 100}] );\n    }\n\nelse if (state_register == \"S3\") {\n    if (roller_pos > 1){\n        roller_pos--;\n        flow.set(\"roller_pos\", roller_pos);\n    }\n    node.send( [{payload: roller_pos}] );\n}\n\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1240,"y":200,"wires":[["a47754ee.cc9948"]]},{"id":"1e034ec8bb4788f4","type":"comment","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"Roller door simulation - nothing to do with controlling the door","info":"","x":1160,"y":60,"wires":[]},{"id":"eb17e5b36d1b92f5","type":"comment","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"Dave's garage door takes 25-second to open or close","info":"","x":1140,"y":100,"wires":[]},{"id":"bbbccb50d0c6ccb6","type":"comment","z":"fc2ffed5c7a37e1d","g":"3f33ed654be29500","name":"Roller door simulation has 100 steps, so each step is 250ms","info":"","x":1360,"y":140,"wires":[]},{"id":"273505a6.34ddaa","type":"ui_group","name":"Garage roller door","tab":"fc0f45ae.d6066","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"fc0f45ae.d6066","type":"ui_tab","name":"Garage roller door","icon":"dashboard","order":45,"disabled":false,"hidden":false}]
In my flow, i have one button for all (down) and one button for all (up).
If you want to control every shutter separately, you have to create those five buttons and then copy them 8 times (all at once).
[{"id":"6ec428cc.625f98","type":"ui_button","z":"b566dad5.172ad8","name":"WZ-R1-Runter","group":"99499a30.68b918","order":4,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-chevron-down","payload":"close","payloadType":"str","topic":"","x":300,"y":340,"wires":[["e1dace16.8417e"]]},{"id":"5ad9a11f.6af31","type":"ui_button","z":"b566dad5.172ad8","name":"WZ-R1-Stop","group":"99499a30.68b918","order":3,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-stop","payload":"stop","payloadType":"str","topic":"","x":290,"y":300,"wires":[["e1dace16.8417e"]]},{"id":"b031e308.a8afa","type":"ui_button","z":"b566dad5.172ad8","name":"WZ-R1-Hoch","group":"99499a30.68b918","order":2,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-chevron-up","payload":"open","payloadType":"str","topic":"","x":290,"y":260,"wires":[["e1dace16.8417e"]]},{"id":"e1dace16.8417e","type":"mqtt out","z":"b566dad5.172ad8","name":"WZ Rollade 1 Command","topic":"shellies/wz-rollade-1/roller/0/command","qos":"","retain":"","broker":"b54780ef.cea3","x":550,"y":280,"wires":[]},{"id":"eeaea17e.9c9ab","type":"ui_text","z":"b566dad5.172ad8","group":"99499a30.68b918","order":1,"width":"3","height":"1","name":"","label":"WZ Rollade 1","format":"","layout":"row-spread","x":116,"y":301,"wires":[]},{"id":"b072a3bb.44cc2","type":"mqtt out","z":"b566dad5.172ad8","name":"WZ Rollade 1 Pos","topic":"shellies/wz-rollade-1/roller/0/command/pos","qos":"","retain":"","broker":"b54780ef.cea3","x":530,"y":220,"wires":[]},{"id":"99499a30.68b918","type":"ui_group","name":"Rolladen-Steuerung","tab":"6e5a41e7.83815","order":1,"disp":true,"width":"6","collapse":false},{"id":"b54780ef.cea3","type":"mqtt-broker","name":"NAS-Mosca","broker":"192.168.1.11","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"6e5a41e7.83815","type":"ui_tab","name":"Wohnzimmer","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
