Hi All
Glad to jump in this forum for my first topic
I installed Nod-red on external virtual machine on Ubuntu 18 at @IP node-red-machine
I want to route http message to my node-red machine to be handled by a HTTP IN Node (POST).
what must be the HTTP routing in order to be handle by Node-Red
I suggest the following routing URL : HTTP://<@IP node-red-machine>/dir1
and
HTP IN Node : POST at URL /dir1
But it does not work
IS there a specific port to open on the node-red machine ?
Thanx 4 your help
Bernie
Hi @Shakey7
by default, Node-RED uses port 1880 so you'd need to include that in the url and ensure that port is properly exposed ... http://ip-of-machine:1880/dir1
Alternatively, you could configure NR to listen on port 80 via the settings file.
Hi knolleary
Thank you
very much for your feedback, it works fine now!
maybe you could tell ole how toi secure the HTTP forward via https on my node-red implementation ?
Anyhow thank's a lot
Bernie
The Node-RED docs have details on security configuration.
Yes I know Julian, but thanks
I have to do my homework
