Hi Guys, I have a case, I'd like to know if you have some example to run container from node-red.
context:
After that i'd like run a container with python code (pandas lib) to inprove mesurements, reports and charts.
What do you mean by 'run a container'.
Hi @Colin I mean start the container like docker container run or docker-compose up.
if you know the terminal command, then perhaps you could do this via an exec node? Alternatively, perhaps node-red-contrib-dockerode will do what you need?
exec
