Run node-red instance as a service with dedicated folder
Hello everyone,
i have installed node-red system-wide on debian and can start with node-red-start on 1880.
The default folder installation is under /home/user/.node-red (hidden with dot).
also the service file is on /lib/systemd/system/nodered.service.
For duplication i have copy the folder .node-red to nodered1 to be used by extra instance nodered1 and the relative service file. then i change in settings.json the port from 1880 to 1881.
Then i have taken all the contents of this service file and try to replicate on another service file under:
sudo nano /etc/systemd/system/nodered1.service
changes:
WorkingDirectory=/home/user/.node-red
WorkingDirectory=/home/user/nodered1
EnvironmentFile=-/home/user/.node-red/environment
EnvironmentFile=-/home/user/nodered1/environment
ExecStart=/usr/bin/env node-red-pi $NODE_OPTIONS $NODE_RED_OPTIONS
The service is not starting probably because of wrong exec start.
anyone has experience with this issue ?
my end goal is to have node-red instance in a custom folder (for backup purposes) and manage this instance as a systemd service.
any suggestions appreciated.
Does
sudo systemctl status nodered1
give any useful indication of the problem? If not then try
journalctl -u nodered1 --no-pager
[Edit]
You have not said, but I presume that you have started the service using
sudo systemctl start nodered1
and if you want it to auto run on startup then
sudo systemctl enable nodered1
You can check out my Alternate Node-RED Installer repo on GitHub. It contains a method for installing localised instances of Node-RED. It does not completely set up the systemd links but has a template you can adapt for yourself.
Hello, yes i see that the instance still using parts of the default instance, like below:
16 Apr 15:13:47 - [info] Settings file : /home/user/.node-red/settings.js
Apr 16 15:13:47 dn-Rmg Node-RED[247536]: 16 Apr 15:13:47 - [info] Context store : 'default' [module=memory]
Apr 16 15:13:47 dn-Rmg Node-RED[247536]: 16 Apr 15:13:47 - [info] User directory : /home/user/.node-red
yes, i have enable and start the service normally like using systemd
in parallel i'm searching more for how to do this, and found this article using different users instance. Local Installs and Managing Node-Red Projects - Steves Node-Red Guide
node-red -u user1 -p 1882
this command creates another user setup and running the instance on another port, which is partly what i need, but this is not running the instance as a service. needs manual start command.
Can you post your systemd script please and the output from the journalctl command
thank you, i will keep this as an option.
Also, did you run
sudo systemctl daemon-reload
or reboot each time you edit the systemd script?
Hello Colin,
this template i have used is from the original instance service located in /lib/systemd/system/nodered.service
[Unit]
Description=Node-RED 1 for ...
Wants=network.target
Documentation=http://nodered.org/docs/hardware/raspberrypi.html
[Service]
Type=simple
# Run as normal pi user - change to the user name you wish to run Node-RED as
User=user
Group=user
Environment="NODE_OPTIONS=--max_old_space_size=2048"
# define an optional environment file in Node-RED's user directory to set custom variables ex>
# uncomment and edit next line if you need an http proxy
#Environment="HTTP_PROXY=my.httpproxy.server.address"
# uncomment the next line for a more verbose log output
#Environment="NODE_RED_OPTIONS=-v"
# uncomment next line if you need to wait for time sync before starting
#ExecStartPre=/bin/bash -c '/bin/journalctl -b -u systemd-timesyncd | /bin/grep -q "systemd-t>
#ExecStart=/usr/bin/env node $NODE_OPTIONS red.js $NODE_RED_OPTIONS
# Use SIGINT to stop
KillSignal=SIGINT
# Auto restart on crash
Restart=on-failure
RestartSec=20
# Tag things in the log
SyslogIdentifier=Node-RED
#StandardOutput=syslog
[Install]
WantedBy=multi-user.target
This is the output:
Apr 16 15:28:30 dn-Rmg Node-RED[250640]: Welcome to Node-RED
Apr 16 15:28:30 dn-Rmg Node-RED[250640]: ===================
Apr 16 15:28:30 dn-Rmg Node-RED[250640]: 16 Apr 15:28:30 - [info] Node-RED version: v4.0.9
Apr 16 15:28:30 dn-Rmg Node-RED[250640]: 16 Apr 15:28:30 - [info] Node.js  version: v20.18.3
Apr 16 15:28:30 dn-Rmg Node-RED[250640]: 16 Apr 15:28:30 - [info] Linux 6.1.0-30-amd64 x64 LE
Apr 16 15:28:31 dn-Rmg Node-RED[250640]: 16 Apr 15:28:31 - [info] Loading palette nodes
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [info] Settings file  : /home/user/.node-red/settings.js
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [info] Context store  : 'default' [module=memory]
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [info] User directory : /home/user/.node-red
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [warn] Projects disabled : editorTheme.projects.enabled=false
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [info] Flows file     : /home/user/.node-red/flows.json
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [info] Creating new flow file
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: ---------------------------------------------------------------------
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: Your flow credentials file is encrypted using a system-generated key.
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: If the system-generated key is lost for any reason, your credentials
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: file will not be recoverable, you will have to delete it and re-enter
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: your credentials.
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: You should set your own key using the 'credentialSecret' option in
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: your settings file. Node-RED will then re-encrypt your credentials
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: file using your chosen key the next time you deploy a change.
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [warn] Encrypted credentials not found
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [error] Unable to listen on http://127.0.0.1:1880/
Apr 16 15:28:32 dn-Rmg Node-RED[250640]: 16 Apr 15:28:32 - [error] Error: port in use
Apr 16 15:28:54 dn-Rmg Node-RED[250732]: 16 Apr 15:28:54 - [info]
it still uses the port 1880, even if i go to settings.js of the folder and change it.
in folder nodered1 / settings.js:
uiPort: process.env.PORT || 1881.
So add them as NODE_RED_OPTIONS in your service file
Environment="NODE_RED_OPTIONS=-p=1882 -u=/home/user/nodered2"
then stop/start the service
NOTE
-u is for userDir (where node-red flows will be saved)
so that should point to an absolute path as I did in the above NODE_RED_OPTIONS example
Did you run daemon-reload?
@Steve-Mcl I can't see why what has been done does not work.
i confirm that options in the service file works.
while the service is starting, is not respecting the settings.js port setting. is trying to load on the default 1880.
Is it using the correct settings file now?
the options in the service is overriding the settings.js file.
So it is still picking up the wrong settings file.
If you add -s /full/path/to/settings.js that should fix that.
Thanks for sharing! I’ve done something similar—make sure ExecStart points to the correct Node-RED binary. Try using which node-red or which node-red-pi to confirm the right path. Also, check permissions and environment file existence. Good luck!
What I do for this is to create another user for each instance and create a new service file, pointing to the new user working directory. Changing the user and group within the service file automatically has it look for/create the .node-red folder with new settings file, or you can create these ahead of creating the new service file. For increased ease of use, I also create a virtual ethernet port with a new IP address and bind the new node-red instance to it so I can use port 1880 (or whatever I want) on all instances (this is optional).
