Using the exec node I'm able to run commands just fine, but when I try to run a script that loads chromium in kiosk mode using the matchbox window manager I get unable to open display errors.
When I run the same script in an SSH session it loads fine and chromium shows up on the Pi's local video output.
I'm just loading the script by running /home/pi/script.sh which contains the commands and parameters for the kiosk mode.
Is it possible to do this? I am doing this to get around chromium crashing to have it reboot the UI a few times a day, I would do a cron job but it has to reset at a specific time which is set inside node-red so I thought I could just have the exec node do it.
