Running Node-RED behind reverse proxy using sub path
I'm trying to install Node-RED behind a nginx reverse proxy. I already have an application under the default "/". I'm setting the Node-RED path via the following:
location /nodeRed { rewrite /nodeRed(.*) /$1 break; proxy_pass http://localhost:1880; }
The call to https://myserver/nodeRed is working, it is getting HTML back... However, the paths to the included javascript, etc, are under the default "/".
Is there a way to set the default path of NodeRED via environment variables, etc?
And they are not loading ?
Do the Devtools console in your browser give any clues ? (screenshot)
If you try (slashes)
location /nodeRed/ {
proxy_pass http://localhost:1880/;
source1
source2 (last comment)
