I have loaded the node-red-chartjs.
I created a simple flow based on the s1seven/node-red-chartjs documentation.
I am trying to get the example in the example to render on my test dashboard. So far I can't get it to show anything. The function output looks good to me, however no chart on the ui.
Here is the output from the the function:
Maybe some one can advise.
[{"id":"319bc1ab0a0be1da","type":"ui_template","z":"7f16363fe0d29b4f","group":"63b0eac674a63a21","name":"Chartjs","order":0,"width":0,"height":0,"format":"<script src=\"/resources/node-red-chartjs/chart.min.js\"></script>\n<script src=\"/resources/node-red-chartjs/chartjs-plugin-annotation.min.js\"></script>\n\n<div>\n <canvas id=\"myChartScatter\" height=\"1\" width=\"1\"></canvas>\n</div>\n<script>\n new Chart(document.getElementById('myChartScatter'), {\n type: 'scatter',\n data: {\n datasets: [{\n label: '{{{payload.legend}}}',\n data: '{{{payload.data}}}',\n showLine: false,\n backgroundColor: 'rgb(255, 99, 132)',\n }],\n },\n options: {\n title: {\n display: true,\n text: '{{{payload.title}}} Content',\n },\n\n plugins: {\n autocolors: false,\n annotation: {\n annotations: {\n minLine: {\n type: 'line',\n borderColor: 'red',\n borderWidth: 1,\n label: {\n enabled: true,\n backgroundColor: 'red',\n borderColor: 'red',\n borderRadius: 10,\n borderWidth: 1,\n content: 'min',\n rotation: 'auto'\n },\n scaleID: 'y',\n value: {{{min}}}\n },\n maxLine: {\n type: 'line',\n borderColor: 'red',\n borderWidth: 1,\n label: {\n enabled: true,\n backgroundColor: 'red',\n borderColor: 'red',\n borderRadius: 10,\n borderWidth: 1,\n content: 'max',\n rotation: 'auto'\n },\n scaleID: 'y',\n value: {{{max}}}\n },\n }\n }\n },\n\n scales: {\n y: {\n beginAtZero: true,\n suggestedMax: {{{max}}} * 1.5,\n },\n x: {\n grid: {\n display: false,\n },\n }\n }\n }\n });\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":460,"y":120,"wires":[["8399e3bbc0928a13"]]},{"id":"63b0eac674a63a21","type":"ui_group","name":"Default","tab":"c3b459709757d3ab","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"c3b459709757d3ab","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Thanks in advance
