sACN filteren van data
good afternoon,
who could help me with the following.
I receive sACN from a light desk (for a light show), I also see this coming in via a debug.
this string consists of 512 steps, I would like to filter this so that only step 5 can pass.
the value is only 0 to 255 and this should be between 0 and 100%.
who knows the solution to make this. added the flow.
groet barry
[{"id":"46a2b97a.cdf2b8","type":"tab","label":"Westhof","disabled":false,"info":""},{"id":"3175211a.dce70e","type":"sacn_in","z":"46a2b97a.cdf2b8","name":"welkom allemaal","universe":1,"interval":"5000","x":280,"y":220,"wires":[["f7acad9.23bc85"]]},{"id":"f7acad9.23bc85","type":"debug","z":"46a2b97a.cdf2b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":600,"y":240,"wires":}]
It would be best to give an example of your string.
Your flow is corrupt as you posted it without backticks
e.g.
code
You can use the range node to change 0-255 to 0-100.
As to your string, as we have not seen it, all I can offer is look at the split node to create an array
yep, range node + post the string, likely can be solved with a function.
while we're on the topic of sACN, does anyone have a good method for sending out sACN data? I see that there are several contrib-nodes that might do this, but they seem like dead projects. i had some loose success with the node-red-contrib-sacn (node) - Node-RED node, but it soon stopped working altogether. no success using OLA + the OLA node, but i also don't have a comp-sci degree...
my goal is to control and (loosely) animate around 30 meters of 30px/m strip, WS2812b, divided into a few universes, controlled by an advatek pixlite IV. thanks to a handy LFO node, the animations won't be an issue (they're not super sophisticated, and i'm trying to achieve this with a raspberry pi, rather than upgrade to a windows box to use touchdesigner), but getting consistent communication to the LED has been the issue.
any sage wisdom out there?
