Hi everyone. i have a problem with my modal. When i test my modal i find that i can only send data once. i cannot save another one only if i deploy the project.
when i reopen my modal and want to write another data i find the input field disabled and i recieve this in my console
any idea PLEASE.?
/* The Modal (background) */
body {font-family: Arial, Helvetica, sans-serif;}
.modal {
display: none; /* Hidden by default */
position: fixed; /* Stay in place */
z-index: 1; /* Sit on top */
padding-top: 100px; /* Location of the box */
left: 0;
top: 0;
width: 100%; /* Full width */
height: 100%; /* Full height */
overflow: auto; /* Enable scroll if needed */
background-color: rgb(0,0,0); /* Fallback color */
background-color: rgba(0,0,0,0.4); /* Black w/ opacity */
/* Modal Content */
.modal-content {
position: relative;
background-color: #e6e6e6;
margin: auto;
padding: 0;
border: 1px solid #888;
width: 50%;
box-shadow: 0 4px 8px 0 rgba(0,0,0,0.2),0 6px 20px 0 rgba(0,0,0,0.19);
-webkit-animation-name: animatetop;
-webkit-animation-duration: 0.4s;
/* Add Animation */
@-webkit-keyframes animatetop {
from {top:-300px; opacity:0}
to {top:0; opacity:1}
@keyframes animatetop {
/* The Close Button */
.close,.close_f {
color: #004d66;
float: right;
font-size: 28px;
font-weight: bold;
.close:hover,
.close_f:hover,
.close:focus,
.close_f:focus {
color: #000;
text-decoration: none;
cursor: pointer;
.modal-header {
padding: 20px 16px;
background-color: #004d66;
.modal-body {padding: 2px 16px;}
.modal-footer {
padding: 20px 16px;
#outer
width:100%;
text-align: center;
.inner
display: inline-block;
#myBtn1,#myBtn2,#myBtn3,#myBtn4,#myBtn5 {
border: none;
color: white;
padding: 15px 32px;
text-align: center;
font-size: 16px;
margin: 4px 2px;
cursor: pointer;
i {
padding-right: 0.3em;
</style>
<!-- Trigger/Open The Modal -->
<div id="outer">
<div class="inner"><button class="inner" id="myBtn1">Button1</button></div>
<div class="inner"><button class="inner" id="myBtn2">Button2</button></div>
<div class="inner"><button class="inner" id="myBtn3">Button3</button></div>
<div class="inner"><button class="inner" id="myBtn4">Button4</button></div>
<div class="inner"><button class="inner" id="myBtn5">Button5</button></div>
</div>
<!-- The Modal -->
<div id="myModal" class="modal">
<!-- Modal content -->
<div class="modal-content">
<div class="modal-header">
<span class="close">×</span>
<h2>Saisie votre matricule</h2>
</div>
<div class="modal-body">
<h3>Matricule :</h3> <br>
<input type="number" ng-model="msg.payload.data3" id="matricule" name="matricule" size="100"><br><br>
<button id="myBtn_m">Entrer</button>
</div>
<div class="modal-footer">
</div>
</div>
</div>
<div id="myModal_f" class="modal">
<span class="close_f">×</span>
<h2>Formulaire</h2><br>
</div>
<h3>Nom : </h3><input type="text" ng-model="msg.payload.data1" id="name" name="Nom" placeholder="Nom" required size="77"><br><br>
<h3>Prenom : </h3><input type="text" ng-model="msg.payload.data2" id="prenom" name="Prenom" placeholder="Prenom" required size="77"> <br><br>
<md-button id="myBtn_f" ng-click="send(msg)" ng-disabled="(msg.payload.data1 == null) || (msg.payload.data2 == null)">Enregistrer</md-button>
</div>
</div>
</div>
</div>
<script>
// Get the modal
var modal = document.getElementById('myModal');
var modal_f = document.getElementById('myModal_f');
// Get the button that opens the modal
var btn = document.getElementById("myBtn1");
var btn_m = document.getElementById("myBtn_m");
var btn_f = document.getElementById("myBtn_f");
// Get the <span> element that closes the modal
var span = document.getElementsByClassName("close")[0];
var span_f = document.getElementsByClassName("close_f")[0];
// When the user clicks on the button, open the modal
btn.onclick = function() {
modal.style.display = "block";
btn_m.onclick = function() {
var x = document.getElementById("matricule").value;
if(x == 0 )
{ alert("Entrer votre matricule");
return false;
else{
modal.style.display = "none";
modal_f.style.display = "block";
// When the user clicks on <span> (x), close the modal
span.onclick = function() {
span_f.onclick = function() {
modal_f.style.display = "none";
// When the user clicks anywhere outside of the modal, close it
window.onclick = function(event) {
if ((event.target == modal)||(event.target == modal_f)) {
</script>
