I made a scraping sensor for HA yesterday and all the data is collected as it should. However, i want to repeat this whole process for several URLs. For the moment, i've entered the inject node payload manually, but what i want is for that payload to be collected from a list of several URLs. I've created a non-connected template node with all the URLs i want, but i don't know how to integrate it, or if that's the way to do it.
The 2nd smaller issue, is that i want the HA Sensor node to have the msg.payload.title as HA Config name. I've tried to sneak in "valueType":"msg" in the code, but it's rejected, and naming it msg.payload.name will only name it exactly that. I've tried with double and triple {} brackets, but no luck.
[{"id":"85776cea.2a018","type":"template","z":"4f7a68fe.44caa8","name":"Funds","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n \"global\": \"F00000JORS\",\n \"norge\": \"F00000JORR\",\n \"usa\": \"F0GBR04OTI\",\n \"healthcare\": \"F00000ZFFV\",\n \"teknologi\": \"F00000ZFG1\"\n}","output":"json","x":170,"y":200,"wires":[[]]},{"id":"30cdee7.0c63112","type":"inject","z":"4f7a68fe.44caa8","name":"POST id","topic":"","payload":"F0GBR04NGU","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":100,"y":140,"wires":[["34ea4898.030bb8"]]},{"id":"34ea4898.030bb8","type":"change","z":"4f7a68fe.44caa8","name":"","rules":[{"t":"set","p":"post","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":140,"wires":[["eff86bb0.4dd408","fbd3baa.4f2d348"]]},{"id":"eff86bb0.4dd408","type":"http request","z":"4f7a68fe.44caa8","name":"GET Main","method":"GET","ret":"txt","paytoqs":false,"url":"https://www.morningstar.no/no/funds/snapshot/snapshot.aspx?id={{{post}}}","tls":"","persist":false,"proxy":"","authType":"","x":420,"y":100,"wires":[["b4130d6.7e481f","c4aa1a4a.19cac8","a52fdedc.cc052"]]},{"id":"fbd3baa.4f2d348","type":"http request","z":"4f7a68fe.44caa8","name":"GET History","method":"GET","ret":"txt","paytoqs":false,"url":"https://www.morningstar.no/no/funds/snapshot/snapshot.aspx?id={{{post}}}&tab=1","tls":"","persist":false,"proxy":"","authType":"","x":430,"y":180,"wires":[["a576ce16.8b778","5120fffe.dd8b1","9cd280d1.6cc38","9f3328a5.e32f78"]]},{"id":"c4aa1a4a.19cac8","type":"html","z":"4f7a68fe.44caa8","name":"Title","property":"payload","outproperty":"payload","tag":"h1","ret":"text","as":"multi","x":590,"y":20,"wires":[["7bac34f9.8a751c"]]},{"id":"a52fdedc.cc052","type":"html","z":"4f7a68fe.44caa8","name":"Date","property":"payload","outproperty":"payload","tag":"#overviewQuickstatsDiv tr:nth-child(2) td.line.heading span","ret":"text","as":"multi","x":590,"y":60,"wires":[["4a8bac12.fe9be4"]]},{"id":"b4130d6.7e481f","type":"html","z":"4f7a68fe.44caa8","name":"Price","property":"payload","outproperty":"payload","tag":"#overviewQuickstatsDiv tr:nth-of-type(2) td:nth-of-type(3)","ret":"text","as":"single","x":590,"y":100,"wires":[["32496c07.ab8f64"]]},{"id":"a576ce16.8b778","type":"html","z":"4f7a68fe.44caa8","name":"1 Day","property":"payload","outproperty":"payload","tag":"#returnsTrailingDiv tr:nth-child(3) td.col2.value.number","ret":"text","as":"single","x":590,"y":140,"wires":[["dd4fbafb.021548"]]},{"id":"5120fffe.dd8b1","type":"html","z":"4f7a68fe.44caa8","name":"1 Week","property":"payload","outproperty":"payload","tag":"#returnsTrailingDiv tr:nth-child(4) td.col2.value.number","ret":"text","as":"single","x":600,"y":180,"wires":[["71d3f223.2727cc"]]},{"id":"9cd280d1.6cc38","type":"html","z":"4f7a68fe.44caa8","name":"1 Month","property":"payload","outproperty":"payload","tag":"#returnsTrailingDiv tr:nth-child(5) td.col2.value.number","ret":"text","as":"single","x":600,"y":220,"wires":[["3f2c0d28.20fb42"]]},{"id":"9f3328a5.e32f78","type":"html","z":"4f7a68fe.44caa8","name":"1 Year","property":"payload","outproperty":"payload","tag":"#returnsTrailingDiv tr:nth-child(9) td.col2.value.number","ret":"text","as":"single","x":590,"y":260,"wires":[["38032aee.c1e206"]]},{"id":"37e1e02.3bf122","type":"function","z":"4f7a68fe.44caa8","name":"String>Float","func":"msg.payload = /(?:[^A-z]+)/.exec(msg.payload)[0].replace(\",\",\".\");\nmsg.payload = parseFloat(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":930,"y":200,"wires":[["bdd00546.fec1f8"]]},{"id":"1df05d04.5c5aa3","type":"debug","z":"4f7a68fe.44caa8","name":"","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"payload","targetType":"msg","x":940,"y":80,"wires":[]},{"id":"bdd00546.fec1f8","type":"join","z":"4f7a68fe.44caa8","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"7","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":910,"y":140,"wires":[["1df05d04.5c5aa3","e5900f64.3399c"]]},{"id":"dd4fbafb.021548","type":"change","z":"4f7a68fe.44caa8","name":"day","rules":[{"t":"set","p":"topic","pt":"msg","to":"day","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":140,"wires":[["37e1e02.3bf122"]]},{"id":"71d3f223.2727cc","type":"change","z":"4f7a68fe.44caa8","name":"week","rules":[{"t":"set","p":"topic","pt":"msg","to":"week","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":180,"wires":[["37e1e02.3bf122"]]},{"id":"3f2c0d28.20fb42","type":"change","z":"4f7a68fe.44caa8","name":"month","rules":[{"t":"set","p":"topic","pt":"msg","to":"month","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":220,"wires":[["37e1e02.3bf122"]]},{"id":"38032aee.c1e206","type":"change","z":"4f7a68fe.44caa8","name":"year","rules":[{"t":"set","p":"topic","pt":"msg","to":"year","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":260,"wires":[["37e1e02.3bf122"]]},{"id":"7bac34f9.8a751c","type":"change","z":"4f7a68fe.44caa8","name":"title","rules":[{"t":"set","p":"topic","pt":"msg","to":"title","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":20,"wires":[["bdd00546.fec1f8"]]},{"id":"4a8bac12.fe9be4","type":"change","z":"4f7a68fe.44caa8","name":"date","rules":[{"t":"set","p":"topic","pt":"msg","to":"date","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":60,"wires":[["bdd00546.fec1f8"]]},{"id":"32496c07.ab8f64","type":"change","z":"4f7a68fe.44caa8","name":"price","rules":[{"t":"set","p":"topic","pt":"msg","to":"price","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":100,"wires":[["37e1e02.3bf122"]]},{"id":"e5900f64.3399c","type":"ha-entity","z":"4f7a68fe.44caa8","name":"","server":"e707d943.9c83a8","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"payload.title"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"kr"}],"state":"payload.price","stateType":"msg","attributes":[{"property":"date","value":"payload.date","valueType":"msg"},{"property":"day","value":"payload.day","valueType":"msg"},{"property":"week","value":"payload.week","valueType":"msg"},{"property":"month","value":"payload.month","valueType":"msg"},{"property":"year","value":"payload.year","valueType":"msg"}],"resend":true,"outputLocation":"","outputLocationType":"none","x":1090,"y":140,"wires":[[]]},{"id":"e707d943.9c83a8","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
