I've got the soft boot going!.Two large invisible buttons w/o focus in the lower LH and RH corners -> JOIN node -> (2) SWITCH nodes. JOIN combines button presses from both buttons, either ones or zeros for a total of four, then sends that string to each SWITCH node, which are set for different number sequences. With the correct number combo, that SWITCH triggers it's NOTIFICATION node, which then pops up with either "Soft Reboot" or "Hard Reboot". Pressing "Reboot" or "Cancel" -> SWITCH node -> EXEC node with "sudo shutdown" & "-r now". or otherwise for "Cancel". I need to make that shutdown instead of hard boot though.
Still contemplating the shutdown, as it would take some effort to remove/restore physical power to the pi. I guess for the shutdown command, one must remove and restore power? No other way?
If you try this, the buttonLeft & buttonRight backgrounds needs to be #000, I left them red for show.
Russ
[{"id":"e3729e2.ffb6d6","type":"ui_template","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","group":"4ed5c42b.ce13dc","name":"ButtonLeft - 0","order":1,"width":3,"height":3,"format":"<button class=\"buttonLeft\" type=\"button\" ng-click=\"send({payload: 0})\">LEFT</button>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":240,"y":660,"wires":[["2960ccbf.be310c"]]},{"id":"6fcc0177.b5dc68","type":"ui_template","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","group":"40f30843.03128","name":"misc css","order":1,"width":0,"height":0,"format":"<style>\n\n/* sets font size for ALL text nodes label property */\n.nr-dashboard-theme .nr-dashboard-text .label {\n font-size: 24px;\n}\n\n/* sets font size for ALL text nodes .value property */\n.nr-dashboard-theme .nr-dashboard-text .value {\n font-size: 30px;\n }\n \n/* sets OPERATE button properties */ \n.button {\n display: inline-block; /* needed to set size/padding */\n padding: 15px 25px; /* spacing around button text */\n font-size: 36px;\n cursor: pointer;\n text-align: center;\n text-decoration: none;\n outline: none;\n color: #fff; /* button text color - white */\n background-color: #4CAF50; /* button body color - green */\n border: none;\n border-radius: 12px;\n box-shadow: 0 9px #3c6026; /* button up shadow color */\n}\n.button:active {\n background-color: #4CAF50;\n box-shadow: 0 5px #000; /* button down shadow color */\n transform: translateY(4px);\n}\n\n/* sets buttonLeft properties */ \n.buttonLeft {\n display: inline-block; /* needed to set size/padding */\n padding: 48px 24px; /* spacing around button text */\n font-size: 48px;\n cursor: pointer;\n text-align: center;\n border: none;\n color: #000; /* button text color - white */\n background-color: #c00; /* button body color - black */\n}\n\n.buttonLeft:focus {\n outline: none;\n box-shadow: none;\n}\n\n/* sets ButtonRight properties */ \n.buttonRight {\n display: inline-block; /* needed to set size/padding */\n padding: 48px 24px; /* spacing around button text */\n font-size: 48px;\n cursor: pointer;\n text-align: center;\n border: none;\n color: #000; /* button text color - white */\n background-color: #c00; /* button body color - black */\n}\n\n.buttonRight:focus {\n outline: none;\n box-shadow: none;\n}\n\n</style>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","x":500,"y":640,"wires":[[]],"info":"NOTE: Do not add comments - everything breaks!"},{"id":"2960ccbf.be310c","type":"join","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","name":"Add #s","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"","joinerType":"str","accumulate":false,"timeout":"3","count":"4","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":270,"y":720,"wires":[["d0dc4bf9.2fc","aeb00edb.b6a528"]]},{"id":"edac3f02.2edb38","type":"ui_template","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","group":"4ed5c42b.ce13dc","name":"ButtonRight - 1","order":2,"width":3,"height":3,"format":"<button class=\"buttonRight\" type=\"button\" ng-click=\"send({payload: 1})\">RIGHT</button>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":240,"y":780,"wires":[["2960ccbf.be310c"]]},{"id":"e96dd6d7.e57a28","type":"switch","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","name":"Runs Command","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Reboot","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":490,"y":780,"wires":[["5d364351.5b309c"],[]]},{"id":"aeb00edb.b6a528","type":"switch","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","name":"0001","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0001","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":720,"wires":[["f1fe023d.1d5e4"]]},{"id":"d0dc4bf9.2fc","type":"switch","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","name":"1001","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1001","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":680,"wires":[["8ff5de7b.6299c"]]},{"id":"8ff5de7b.6299c","type":"change","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","name":"blanker","rules":[{"t":"change","p":"payload","pt":"msg","from":"1001","fromt":"num","to":" ---- HARD Reboot ----","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":680,"wires":[["3b6a731.500c30c"]]},{"id":"f1fe023d.1d5e4","type":"change","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","name":"blanker","rules":[{"t":"change","p":"payload","pt":"msg","from":"0001","fromt":"num","to":" ---- SOFT Reboot ----","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":720,"wires":[["425d72b.58de40c"]]},{"id":"3b6a731.500c30c","type":"ui_toast","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","position":"dialog","displayTime":"10","highlight":"red","sendall":true,"outputs":1,"ok":"Reboot","cancel":"Cancel","raw":false,"topic":"","name":"hReboot","x":690,"y":680,"wires":[[]]},{"id":"425d72b.58de40c","type":"ui_toast","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"Reboot","cancel":"Cancel","raw":false,"topic":"","name":"sReboot","x":690,"y":720,"wires":[["e96dd6d7.e57a28"]]},{"id":"5d364351.5b309c","type":"exec","z":"c199b9b6.017a2","g":"7e4507b4.d3a11","command":"sudo shutdown","addpay":false,"append":" -r now","useSpawn":"true","timer":"","oldrc":false,"name":"Soft Reboot","x":690,"y":780,"wires":[[],[],[]]},{"id":"4ed5c42b.ce13dc","type":"ui_group","z":"","name":"Hidden Reboot Buttons","tab":"81831aab.f2f568","order":7,"disp":false,"width":"6","collapse":false},{"id":"40f30843.03128","type":"ui_group","z":"","name":"Button","tab":"81831aab.f2f568","order":5,"disp":false,"width":6,"collapse":false},{"id":"81831aab.f2f568","type":"ui_tab","z":"","name":"GTO-500 Gate Opener","icon":"dashboard","disabled":false,"hidden":false}]
Errr, forgot my screengrabs, one with colored buttons and one with black bg's:
