SDS011 contrib, problem with installation
Hi there.
I'm trying to install the SDS011 sensor node in my rapsberry pi3, you can find it here: https://flows.nodered.org/node/node-red-contrib-sds011
Actually i'm running npm@6.13.4 and node@v12.15.0.
I wish that it's not a problem with compatibility between the node and my version of nodejs, or something like this.
When i try to run the script: npm install node-red-contrib-sds011, this is the answer.
Any ideas?
Thanks.
> serialport@6.2.2 install /home/pi/node_modules/node-red-contrib-sds011/node_modules/serialport
> prebuild-install || node-gyp rebuild
>prebuild-install WARN install No prebuilt binaries found (target=12.15.0 runtime=node arch=arm platform=linux)
make: ingresso nella directory "/home/pi/node_modules/node-red-contrib-sds011/node_modules/serialport/build"
  CXX(target) Release/obj.target/serialport/src/serialport.o
In file included from ../src/./serialport.h:6,
                 from ../src/serialport.cpp:1:
../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
   v8::String::Utf8Value path(info[0]->ToString());
In file included from /home/pi/.cache/node-gyp/12.15.0/include/node/node.h:63,
                 from ../../../../nan/nan.h:54,
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:2572:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’
   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:2572:44: note:   candidate expects 1 argument, 0 provided
In file included from /home/pi/.cache/node-gyp/12.15.0/include/node/v8-internal.h:14,
                 from /home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:25,
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:2588:31: note: candidate: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’
                 Local<String> ToString(Isolate* isolate) const);
/home/pi/.cache/node-gyp/12.15.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’
   declarator __attribute__((deprecated(message)))
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:2588:31: note:   candidate expects 1 argument, 0 provided
../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
   v8::Local<v8::Object> options = info[1]->ToObject();
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:2576:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’
   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:2576:44: note:   candidate expects 1 argument, 0 provided
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:2590:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’
                 Local<Object> ToObject(Isolate* isolate) const);
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:2590:31: note:   candidate expects 1 argument, 0 provided
../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
   data->callback.Call(2, argv);
../../../../nan/nan.h:1740:3: note: declared here
   Call(int argc, v8::Local<v8::Value> argv[]) const {
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
 uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
   data->callback.Call(1, argv);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
 an::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:3403:22: note: declared here
                 bool Set(Local<Value> key, Local<Value> value));
../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
 an::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
 an::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
 eue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
 ::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: At global scope:
../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
 SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
 SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
   void init(v8::Handle<v8::Object> target) {
../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
                                    tzset
In file included from ../../../../nan/nan.h:54,
../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
 NODE_MODULE(serialport, init);
/home/pi/.cache/node-gyp/12.15.0/include/node/node.h:560:36: note: in definition of macro ‘NODE_MODULE_X’
       (node::addon_register_func) (regfunc),                          \
../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
/home/pi/.cache/node-gyp/12.15.0/include/node/node_object_wrap.h:84:78:   required from here
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:10004:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                reinterpret_cast<Callback>(callback), type);
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
../../../../nan/nan_object_wrap.h:65:61:   required from here
/home/pi/.cache/node-gyp/12.15.0/include/node/v8.h:10004:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
make: *** [serialport.target.mk:110: Release/obj.target/serialport/src/serialport.o] Error 1
make: uscita dalla directory "/home/pi/node_modules/node-red-contrib-sds011/node_modules/serialport/build"
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack     at ChildProcess.emit (events.js:223:5)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
gyp ERR! System Linux 4.19.97-v7+
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/pi/node_modules/node-red-contrib-sds011/node_modules/serialport
gyp ERR! node -v v12.15.0
gyp ERR! node-gyp -v v5.0.5
gyp ERR! not ok
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN pi No description
npm WARN pi No repository field.
npm WARN pi No README data
npm WARN pi No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the serialport@6.2.2 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     /home/pi/.npm/_logs/2020-02-09T11_08_06_720Z-debug.log
You should be in the .node-red directory when you run the npm install command, I suspect you may still get the error though.
That node depends on serialport v6 - I think you will need version 7 or even 8 in order to compile on nodejs 12. It may work if you drop back to node 10.
thx.
how may i do that? I try with:
curl -sL https://deb.nodesource.com/setup_10.x | sudo bash -
but the node version is still v12.15.0
You probably need to uninstall 12 first and remove nodesource.list from /etc/apt/sources.list.d dir then retry that command
tried, but still v12.15.0
What does
apt policy nodejs
show? Post it here.
Also you did run
sudo apt install nodejs
after running the curl command I hope.
ok, i tried to uninstall nodejs following this guide:
then i run:
sudo apt-get install nodejs
If i try to run node-v or node --version, it shows an error:
bash: /usr/local/bin/node: File or directory doesn't exist (translation from italian)
but, if i run
apt policy nodejs
this is the answer:
nodejs:
  Installato: 10.19.0-1nodesource1
  Candidato:  10.19.0-1nodesource1
  Tabella versione:
 *** 10.19.0-1nodesource1 500
        500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
        100 /var/lib/dpkg/status
     10.15.2~dfsg-2+rpi1 500
        500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
I've tried to install node red and the node for my sensor again.
Result by installing the sensor node: no errors but some warnings. I have suppose to see the node in my node red dashboard (the one that i reach with http://myipaddres:1880), but it doesn't appear.
> serialport@6.2.2 install /home/pi/node_modules/serialport
prebuild-install WARN install No prebuilt binaries found (target=10.19.0 runtime=node arch=arm platform=linux)
make: ingresso nella directory "/home/pi/node_modules/serialport/build"
../src/serialport.cpp:41:49: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
In file included from /home/pi/.cache/node-gyp/10.19.0/include/node/v8.h:26,
                 from /home/pi/.cache/node-gyp/10.19.0/include/node/node.h:63,
                 from ../../nan/nan.h:54,
/home/pi/.cache/node-gyp/10.19.0/include/node/v8.h:2892:28: note: declared here
                   explicit Utf8Value(Local<v8::Value> obj));
/home/pi/.cache/node-gyp/10.19.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
../src/serialport.cpp:48:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
In file included from /home/pi/.cache/node-gyp/10.19.0/include/node/node.h:63,
/home/pi/.cache/node-gyp/10.19.0/include/node/v8.h:10046:15: note: declared here
 Local<Object> Value::ToObject() const {
../src/serialport.cpp:113:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/serialport.cpp:250:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
In file included from ../../nan/nan.h:54,
/home/pi/.cache/node-gyp/10.19.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
/home/pi/.cache/node-gyp/10.19.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
/home/pi/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
/home/pi/.cache/node-gyp/10.19.0/include/node/node_object_wrap.h:84:78:   required from here
/home/pi/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
/home/pi/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
/home/pi/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
  CXX(target) Release/obj.target/serialport/src/serialport_unix.o
In file included from ../src/serialport.h:6,
                 from ../src/serialport_unix.cpp:2:
../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
  CXX(target) Release/obj.target/serialport/src/poller.o
In file included from ../src/poller.cpp:1:
../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
   obj->callback.Call(2, argv);
  CXX(target) Release/obj.target/serialport/src/serialport_linux.o
  SOLINK_MODULE(target) Release/obj.target/serialport.node
  COPY Release/serialport.node
make: uscita dalla directory "/home/pi/node_modules/serialport/build"
npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
+ node-red-contrib-sds011@0.0.1
updated 1 package, moved 19 packages and audited 3026 packages in 31.723s
found 0 vulnerabilities
Did you do the following, which is necessary after changing the nodejs version?
First stop node red then reinstall node-red to build it with the new nodejs and then rebuild any other nodes installed
sudo npm install -g --unsafe-perm node-red
cd ~/.node-red
npm rebuild
then restart node-red
did it.
But still i don't see the node in my node list.
Stop node red then start it using
node-red-start
and post the full output here. Also post the result of
npm list node-red-contrib-sds011
Here you have the output for node-red-start command. I cover the ip address with "x".
Start Node-RED
Once Node-RED has started, point a browser at http://xxx.xxx.x.xxx:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-start                         to start Node-RED again
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
10 Feb 00:34:14 - [info]
Welcome to Node-RED
10 Feb 00:34:14 - [info] Node-RED version: v1.0.3
10 Feb 00:34:14 - [info] Node.js  version: v10.19.0
10 Feb 00:34:14 - [info] Linux 4.19.97-v7+ arm LE
10 Feb 00:34:15 - [info] Loading palette nodes
10 Feb 00:34:18 - [info] Settings file  : /home/pi/.node-red/settings.js
10 Feb 00:34:18 - [info] Context store  : 'default' [module=memory]
10 Feb 00:34:18 - [info] User directory : /home/pi/.node-red
10 Feb 00:34:18 - [warn] Projects disabled : editorTheme.projects.enabled=false
10 Feb 00:34:18 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
10 Feb 00:34:18 - [info] Creating new flow file
your credentials.
10 Feb 00:34:18 - [info] Starting flows
10 Feb 00:34:18 - [info] Started flows
10 Feb 00:34:18 - [info] Server now running at http://xxx.x.x.x:1880/
results for npm list node-red-contrib-sds011 command:
/home/pi
└── node-red-contrib-sds011@0.0.1
And with this results, maybe i understand the problem... is that the right path? :slight_smile:
Thanks for helping.
If you install nodes manually, on the Pi always change to the .node-red directory before using the npm command. You might want to remove that node, cd .node-red and reinstall it.
And finally, i got it!
Just give me some hours to test it.
Thankyou so much to all of you for the help!
Ok, here i am...
thanks to you, I think that i'm at a good point (and consider that it's my firt rednode project.
Actually, i try to set a flow implementing a serial input, the sensor node, and 3 payloads.
I set the serial node with this sets
and I hadn't touch the SDS011 configuration. I tried to deploy, and I show you the results... ideas? :frowning:
Looks like incorrect baud rate. What does a debug node on the serial port show.
Hope that i set the flow in the correct way to answer you.
Presumably that is not what you are expecting. Are you sure the baud rate is correct?
