"Search" and how good it is/n't. I'm stuck
Folks, I nearly posted the other day and didn't because I nearly shot myself in the foot with the question I was about to ask.
This is (maybe) a better worded version.
Though I am not 100% sure there seems to be something happening at 05:00 (within a minute) daily.
This problem was not quite at the level of needing to be fixed but was annoying.
I would get a report that at 05:00 (local) the WAP would go down then come back.
ITMT, I had other problems and was working on them.
Progress on those was made and this problem seemed to stop. (Weird)
So going further down the track of the other problem I got things fixed. Not sure about that, but....
So last night was the first time all the other problem's problems should have been fixed.
I got up and the problem (the one on which I was working later on) did seem to now be working.
But it was indicating the first (bigger) problem of the WAP going down.
I looked at the logs (mine, not system) and though the WAP hadn't gone down, there were reports shown at 05:00 (within a couple of minutes) a problem had happened.
(Edit) Sorry, it supposedly did.)
SOMEWHERE I know (or am very suspicious) I have a delay node that delays a message by 5 hours.
How can I find this node easily?
Searching for 5 is just painful. As is searching for delay.
If I was 5 hours 25 minutes it would be a lot easier - as I discovered yesterday.
As the node doesn't support that in that way, I have to make it .... 325 minutes.
325 is a bit easier to find than 5.
Any tricks I can use to find this delay node?
Try searching for type:delay 5
Thanks.
That reduced the results shown, but it still seems open to ambiguity.
But it did help find said node.
Ok, not shown in that list, I found the node.
But picking another one which was shown....
I'm not sure where the 5 comes into the equation.
NR 1.3.5 (Sorry)
You could use a flow to find all delay nodes set to 5 hours:
        "id": "a531e868a7ed264e",
        "type": "tab",
        "label": "Flow 4",
        "disabled": false,
        "info": "",
        "env": []
        "id": "12779a7f48341b48",
        "type": "file in",
        "z": "a531e868a7ed264e",
        "filename": "/home/pi/.node-red/flows_GlassPi.json",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 330,
        "y": 80,
                "33f178bf3eb192bb"
        "id": "33f178bf3eb192bb",
        "type": "json",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 550,
        "y": 80,
                "4493558531e4c276"
        "id": "e88685b22d44162a",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 100,
        "y": 80,
                "12779a7f48341b48"
        "id": "09e583bb417767c1",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 830,
        "y": 80,
        "id": "4493558531e4c276",
        "type": "function",
        "func": "var msg1 = {};\nfor (var i = 0; i < msg.payload.length; i++) {\n    if (msg.payload[i].type == \"delay\" & msg.payload[i].timeout == \"5\" & msg.payload[i].timeoutUnits == \"hours\"){\n        msg1.payload = msg.payload[i];\n        node.send(msg1);\n    }\n}\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 680,
        "y": 80,
                "09e583bb417767c1"
That is cute.
Thanks.
I have saved that and may use it in the future if/when I need to do such tricky searches.
I'll just have to learn the syntax for the searching. But it works. :wink:
As a guess, the node's id has a 5 in it
You are probably right.
It is just that fact blurs the line between useful searching and not useful.
