Hi
I need to make a search in a Json to find a number, and then return an other number, i did try to make a little flow to explane my quest.
my json is converted from a xml and imported from a file, but this is not in this demo flow, so it is not intended to be in a inject node
I uploaded the flow because it is to big to insert here.
flows.json (171.8 KB)
Can someone please help me in the right direction ?
Hello Zamzon,
msg.payload = msg.payload.DeviceDetails.find(el => el.DeviceInfo.box_number === "46")
this will return the first matching object from the array of DeviceDetails where its DeviceInfo.box_number equals with string 46 (note that your values are stored as strings so check for strings)
afterwords i didnt understand the criteria to return the logical_area since logical_area is in the array LoadControlChannelList
Thanks,
It should look under LoadControlChannelList under the right Deviceinfo for "channel" (2) and then return Logical_area for the right LoadControlChannelList
I updated the function.
var box_number = 46;
var channel = 2; // LoadControlChannelList
//Search in DeviceDetails 0-26 for box_number 46
//It's found here:
//payload.DeviceDetails[3].DeviceInfo.box_number
//And then print the logical_area for the right DeviceDetails:
//msg.payload = msg.payload.DeviceDetails[3].LoadControlChannelList[2].logical_area
ok .. this makes more sense .. so you need from channel (2)
msg.payload = msg.payload.LoadControlChannelList[2].logical_area // channel(2)
Hi
I'm trying to insert the new code into the rest of my code, then I can't get box_number from my float
this dosn't work and return 46
boxnr = flow.get("boxnr");
this works perfect and return "46"
boxnr = "46";
var channel = 2;
msg.payload = msg.payload.DeviceExport.DeviceDetails.find(el => el.DeviceInfo[0].$.box_number === boxnr)
msg.payload = msg.payload.LoadControlChannelList[0].LoadControlChannel[channel].$.logical_area
I'm receiveing 46 from my float.get, but i can only get it to work if I insert "" so it looks line "46"
The === means exact match. I.e. 46 is not === equal to "46"
You could use parseInt around the values or change to == or coerce the boxnr to a string e.g. var boxnr = "" + flow.get("boxnr")
Thanks again, it works perfectly
