may be I searched wrong but I am searching for the API which describes me for example this.on('input', ....), this.on('close', ....) and the other possibilites.
I am developing a custom node and it's works fine. For example I am using the this.on('input', function(msg, send, done){...}) because I saw it in the examples, also I found this.on('close', function(msg){...}) anywhere in the forum but I want an overview of the other possibilities but I have no starting point I am not be able to find 'input', 'close' anywhere in den API.
Can somebody give me a hint for a good search expression please?
- Update:
I have took a look to core/storage/23-watch.js and there are also 'change' and 'error'.
Thank you for the answer.
Yes, there are 'input', 'close' but in my first update I also found 'change' and 'error'. May be it's a misunderstanding on my site but it's seems to me there are more events that you can use.
Another point is the "flows:started" runtime event from @node-red/runtime/lib/flows/index.js . It's not documented in RED.events : Node-RED . I found this hint anywhere in the forum and currently I am not sure if I use the correct documentation or the information intentionally hidden for the common developer.
I have the feeling that certain something is missing to feel me save.
The docs you've linked to are for the events available within the editor.
We do not have a publicly documented set of runtime events beyond what is in the Creating Nodes docs.
Getting a more formalized set of runtime events is on the to-do list
Thank you for the answer!
In the last months the self doubts grew up that I missed something because I am completly new in Node-RED, but this explains it to me.
Does it make sense to collect such findings/events for later usage at a central point for other developers and to make it easier to fulfill the to do? The big exclamation mark shouldn't be absent for using it on own risk.
