Securing Node-RED and using node-red-contrib-tfjs-coco-ssd
Just to inform. If you have password protected the node-defined HTTP endpoints (httpNodeRoot), or the static content (httpStatic) in settings,js, the node will fail in it's attempt loading the model
If you change the default setting and add the user:password combination you have used in settings.js like below, the model will load :wink:
If you have secured it with certificates etc etc (https) I don't know how it should be configured or if it then is possible or not
If you leave the url blank it will try to load from internet instead so should be ok. (just takes longer... but shorter than not loading of course)
