Hi together,
I built the folowing flow:
I use it to get data from a database. I have to choose the element of the array manually.
In my example it is element 1.
This is the corresponding code:
Node "Datenabfrage_FROM_orders:
msg.topic = "SELECT * FROM orders";
Node "Abfrage Auftragsinformationen":
//choose an element from the array of the database
var o_id = 1;
var number_items = msg.payload[o_id].number_items;
var number_finished = msg.payload[o_id].number_finished;
var itemstatus = {};
itemstatus.labels = ["Herzustellen", "Fertiggestellt"];
itemstatus.data = [[number_items, number_finished]];
itemstatus.series = ["Sales"];
var prozent_finished = parseInt([(number_finished / number_items)*100])
var test = itemstatus.data[0][1];
return [{payload:[itemstatus],topic:msg.topic},
{payload: prozent_finished},
{payload: test},
{payload: o_id}
This works and the data are shown on the dashboard.
But now I want to choose an element from the array by tiping in a number on the dashboard and not changing the function node "Abfrage Auftragsinformationen" all the time manually. My plan is to use the "form" node.
I have tried a lot of ways to realise this plan, but I have only little experience.
There are always new errors (e.g. syntax errors) and I have absolutly no idea how to realise my idea.
Can somebody help me, please.
If it is not understandable what I wanted to explain or if you need more information, please ask.
Tank you in advance
(Sorry, as a new member I'm just allowed to post 1 image)
