Send data from Node red to UI Builder
Hi,
Hope you guys are doing well. I have been following the threads related to Soket.io, so that data from Node red could be sent to UI Builder.
Currently Im facing a problem related to get the data in UI Builder. I could fetch the msg.payload from Node red on the Java script function I have written. Even when I copy paste the solution for virtual Shopfloor from @ [TotallyInformation] ( Uibuilder + VueJS + SVG = visual IoT floorplan )
could see the tags such mentioned in part Mounted such as .onChange.
But whatever changes I make in Html and java script i can see it on the UI Builder.
For Info :
npm version - 8.12.2
node version - v16.14.0
Could you please help me, where am I making mistake.
Thank you in advance.
