I have an array msg.options =[1,2,3,4,5], and i want to send each item in msg.payload.
i used this in function
for( var i = 0; i < msg.options.length; i++){
msg.payload = msg.options[i]
But it always send me the first item. msg.options[0].
Any ideas will be appreciated.
You will find a code ready to use in the docs. See Multiple Messages:
I would just change the loop in the function as below (personal preference):
let SplitMsg=[];
for (let elem of msg.payload) {
SplitMsg.push({payload:elem});
return [SplitMsg];
Of just use the split node
FYI, your code was almost perfect, if you had used node.send...
node.send(msg);
Nice to have options (pun intended)
good to know about" node.send". i never used it before. Thank you all.
