many thanks. But this configuration works only with a single message.
If I have multiple messages distingueshed by msg.topic the  trigger node sent only a message.
(see the following flow)
[{"id":"19407975.95b1f7","type":"tab","label":"TEST","disabled":false,"info":""},{"id":"9072b336.4e1e9","type":"function","z":"19407975.95b1f7","name":"extract info","func":"\nreturn [\n\n\t{payload: msg.payload.Stoccaggio},\n\t{payload: msg.payload.Prelievo},\n\t{payload: msg.payload.Alimentazione}\n    \n];","outputs":3,"noerr":0,"x":752.6587905883789,"y":88.52387809753418,"wires":[["adbad9a5.3df078"],["32a22c82.9c4ed4"],["8c144221.4ea41"]],"outputLabels":["Stoccaggio","Prelievo","Alimentazione"]},{"id":"32a22c82.9c4ed4","type":"function","z":"19407975.95b1f7","name":"Prelievo","func":"//msg.payload = Math.floor(msg.payload/3600.0*100)/100;\n\nmsg.topic = 'Prelievo magazzino';\nmsg.soglia = -1;\nmsg.WO_DESC = 'Prelievo magazzino';\nmsg.WORKTYPE = 'FAIL';\nmsg.LOCATION = 'POEMP';\nmsg.WO_STATUS = 'NUOVO';\n\nvar m  = msg.payload*1.5;\nmsg.ui_control = {\"min\":0,\"max\":m}\n\nmsg.url = \"aa\"; \n\nreturn msg;","outputs":1,"noerr":0,"x":1022.4169082641602,"y":88.25006294250488,"wires":[["876030c3.c812"]]},{"id":"876030c3.c812","type":"switch","z":"19407975.95b1f7","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"-1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1209.7383003234863,"y":91.57147407531738,"wires":[["70b8b856.797888"]]},{"id":"87f3534d.9e49a","type":"debug","z":"19407975.95b1f7","name":"Do HTTP Request","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1573.5002708435059,"y":92.00007486343384,"wires":[]},{"id":"8c144221.4ea41","type":"function","z":"19407975.95b1f7","name":"Alimentazione","func":"//msg.payload = Math.floor(msg.payload/3600.0*100)/100;\n\nmsg.topic = 'Contatore Alimentazione';\nmsg.soglia = -1;\nmsg.WO_DESC = 'Contatore Alimentazione';\nmsg.WORKTYPE = 'FAIL';\nmsg.LOCATION = 'POEMP';\nmsg.WO_STATUS = 'NUOVO';\n\nvar m  = msg.payload*1.5;\nmsg.ui_control = {\"min\":0,\"max\":m}\n\nmsg.url = \"aa\"; \n\nreturn msg;","outputs":1,"noerr":0,"x":1045.6669082641602,"y":138.0000514984131,"wires":[["876030c3.c812"]]},{"id":"adbad9a5.3df078","type":"function","z":"19407975.95b1f7","name":"Stoccaggio","func":"//msg.payload = Math.floor(msg.payload/3600.0*100)/100;\n\nmsg.topic = 'Stoccaggio';\nmsg.soglia = -1;\nmsg.WO_DESC = 'Contatore Stoccaggio';\nmsg.WORKTYPE = 'FAIL';\nmsg.LOCATION = 'POEMP';\nmsg.WO_STATUS = 'NUOVO';\n\nvar m  = msg.payload*1.5;\nmsg.ui_control = {\"min\":0,\"max\":m}\n\nmsg.url = \"aa\"; \n\nreturn msg;","outputs":1,"noerr":0,"x":1040.047866821289,"y":37.44049835205078,"wires":[["876030c3.c812"]]},{"id":"d5da8ab.f366678","type":"random","z":"19407975.95b1f7","name":"","low":"1","high":"1000","inte":"true","property":"payload","x":334.5,"y":40.00000762939453,"wires":[["4e261493.d63a7c"]]},{"id":"ef4c7c2e.fde31","type":"inject","z":"19407975.95b1f7","name":"","topic":"Stoccaggio","payload":"","payloadType":"date","repeat":"1","crontab":"","once":true,"onceDelay":0.1,"x":144.10000610351562,"y":40,"wires":[["d5da8ab.f366678"]]},{"id":"c5c0f24f.dcef","type":"inject","z":"19407975.95b1f7","name":"","topic":"Prelievo","payload":"","payloadType":"date","repeat":"1","crontab":"","once":true,"onceDelay":0.1,"x":133,"y":94.00000381469727,"wires":[["973aae07.d2f32"]]},{"id":"514f00f8.35e8c","type":"inject","z":"19407975.95b1f7","name":"","topic":"Alimentazione","payload":"","payloadType":"date","repeat":"1","crontab":"","once":true,"onceDelay":0.1,"x":149,"y":138.0000057220459,"wires":[["afd3aed3.9cf2c"]]},{"id":"973aae07.d2f32","type":"random","z":"19407975.95b1f7","name":"","low":"1","high":"1000","inte":"true","property":"payload","x":332.00000381469727,"y":93.00002861022949,"wires":[["4e261493.d63a7c"]]},{"id":"afd3aed3.9cf2c","type":"random","z":"19407975.95b1f7","name":"","low":"1","high":"1000","inte":"true","property":"payload","x":373.00000762939453,"y":137.6000051498413,"wires":[["4e261493.d63a7c"]]},{"id":"4e261493.d63a7c","type":"join","z":"19407975.95b1f7","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":562.5000114440918,"y":89.00000667572021,"wires":[["9072b336.4e1e9"]]},{"id":"70b8b856.797888","type":"trigger","z":"19407975.95b1f7","op1":"","op2":"","op1type":"pay","op2type":"payl","duration":"30","extend":false,"units":"s","reset":"","bytopic":"all","name":"","x":1374.1000747680664,"y":88.00000190734863,"wires":[["87f3534d.9e49a"]]}]
Can I handle this behavior in a different way?
many thanks again for your help
