Send Message Once
Hi all,
I am sure this is such a simple thing I am almost to embarrassed to ask. I have a simple flow, reads a value from MQTT (Grid voltage), checks if the value is in range using a switch node. If the value is =< it sends a notification using PushSafer and Pushover notification service.
This works well, what I didnt factor for is using the switch node while the value is =< the value I set it constantly sends the message. So during a outage I keep getting the messages.
The intent is for it to only notify me once and not constantly.
My question(s):
  1. Did I use the wrong node (Switch node)
  2. What do you recommend I use - the requirement is to only send me the message ONCE as the voltage drops below =< value.
Thank you as usual!
You can use the RBE (filter node) to inhibit
e.g, something like this...
chrome_TadPBhacou
Demo flow (use CTRL-I to import)
[{"id":"3b79ef6fd5d51486","type":"inject","z":"7eecf5f1d763605a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":352,"y":592,"wires":[["c9e1ac81b650e7ff"]]},{"id":"c9e1ac81b650e7ff","type":"switch","z":"7eecf5f1d763605a","name":"Less than  8  ?","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"8","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":574,"y":640,"wires":[["1520ddd85115b2c0","a99855f1540228b7"],["35eb622363138bed","6c9a281f1d50b7ea"]]},{"id":"7aef8b8ccb2e899a","type":"inject","z":"7eecf5f1d763605a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"5","payloadType":"num","x":350,"y":656,"wires":[["c9e1ac81b650e7ff"]]},{"id":"b64347d09d559c8c","type":"inject","z":"7eecf5f1d763605a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"10","payloadType":"num","x":350,"y":720,"wires":[["c9e1ac81b650e7ff"]]},{"id":"1520ddd85115b2c0","type":"debug","z":"7eecf5f1d763605a","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":762,"y":576,"wires":[]},{"id":"35eb622363138bed","type":"debug","z":"7eecf5f1d763605a","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":778,"y":720,"wires":[]},{"id":"a99855f1540228b7","type":"change","z":"7eecf5f1d763605a","name":"WARNING. Value is below 8","rules":[{"t":"set","p":"payload_original","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"WARNING. Value is below 8","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":824,"y":624,"wires":[["f7c2fa40d22983da"]]},{"id":"6c9a281f1d50b7ea","type":"change","z":"7eecf5f1d763605a","name":"Normal (Above 8)","rules":[{"t":"set","p":"payload","pt":"msg","to":"Normal (Above 8)","tot":"str"},{"t":"set","p":"payload_original","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":794,"y":656,"wires":[["f7c2fa40d22983da"]]},{"id":"f7c2fa40d22983da","type":"rbe","z":"7eecf5f1d763605a","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1040,"y":640,"wires":[["d080866a75cdc7d8"]]},{"id":"d080866a75cdc7d8","type":"debug","z":"7eecf5f1d763605a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"msg","x":1074,"y":688,"wires":[]}]
Thank you! Let me try that.
