Send payload of array to UI-Template Table
the ui-template flow now transfered to ui-table flow:
        "id": "fd3a93decc2a1270",
        "type": "tab",
        "label": "e.g. ui-table",
        "disabled": false,
        "info": ""
        "id": "ec34c6ada52855bd",
        "type": "change",
        "z": "fd3a93decc2a1270",
        "name": "Table Configuration",
        "rules": [
                "t": "set",
                "p": "ui_control",
                "pt": "msg",
                "to": "$format := {\t   \"tabulator\": {\t        \"tableBuilt\":\"function(){this.tablebuilt = true;}\",\t        \"dataLoaded\":\"function(data){if(this.tablebuilt){this.tablebuilt=false; this.send({topic:'build table', ui_control:{callback:'tableBuilt'}})}else{this.send({topic:'success', ui_control:{callback:'setData'}, return:{command:'setData', arguments:[data]}})}}\"\t    }\t}",
                "tot": "jsonata"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "{}",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 730,
        "y": 220,
                "31731e53875dacf5"
        "icon": "node-red/cog.svg"
        "id": "863b8f9b8d52963d",
        "type": "inject",
        "props": [
                "p": "payload",
                "v": "-1",
                "vt": "num"
                "p": "topic",
                "v": "",
                "vt": "string"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "-1",
        "payloadType": "num",
        "x": 230,
        "y": 220,
                "ec34c6ada52855bd"
        "id": "29ee456cbd10be91",
        "type": "debug",
        "name": "TABLE",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1370,
        "y": 100,
        "id": "31731e53875dacf5",
        "type": "ui_table",
        "group": "d04cb83acc2064af",
        "name": "Content",
        "order": 1,
        "width": "20",
        "height": "12",
        "columns": [
                "field": "no",
                "title": "No",
                "width": "",
                "align": "left",
                "formatter": "rownum",
                "formatterParams": {
                    "target": "_blank"
                "field": "name",
                "title": "Name",
                "width": "",
                "align": "left",
                "formatter": "plaintext",
                    "target": "_blank"
                "field": "id",
                "title": "ID",
                "width": "",
                "align": "left",
                    "target": "_blank"
                "field": "address",
                "title": "Address",
                "width": "",
                "align": "left",
                    "target": "_blank"
                "field": "country",
                "title": "Contry",
                "width": "",
                "align": "left",
                    "target": "_blank"
                "field": "occupation",
                "title": "Occupation",
                "width": "",
                "align": "left",
                    "target": "_blank"
                "field": "age",
                "title": "Age",
                "width": "",
                "align": "left",
                    "target": "_blank"
                "field": "timestamp",
                "title": "Timestamp",
                "width": "",
                "align": "left",
                    "target": "_blank"
        "outputs": 1,
        "cts": true,
        "x": 1140,
        "y": 220,
                "f18a891c4099b790",
                "29ee456cbd10be91"
        "id": "a2696265f95db3aa",
        "type": "ui_button",
        "group": "21028a285361e1fc",
        "order": 2,
        "width": 0,
        "height": 0,
        "passthru": false,
        "label": "Clear Database",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "",
        "payloadType": "str",
        "topic": "clear all",
        "topicType": "str",
        "x": 200,
        "y": 500,
                "821293d40021dc19"
        "id": "0f7aca16675ee795",
        "type": "ui_form",
        "label": "New Item",
        "order": 1,
        "width": 0,
        "height": 0,
        "options": [
                "label": "Name",
                "value": "name",
                "type": "text",
                "required": true,
                "rows": null
                "label": "Address",
                "value": "address",
                "type": "text",
                "required": true,
                "rows": null
                "label": "Country",
                "value": "country",
                "type": "text",
                "required": true,
                "rows": null
                "label": "Occupation",
                "value": "occupation",
                "type": "text",
                "required": true,
                "rows": null
                "label": "Age",
                "value": "age",
                "type": "text",
                "required": true,
                "rows": null
        "formValue": {
            "address": "",
            "country": "",
            "occupation": "",
            "age": ""
        "payload": "",
        "submit": "submit",
        "cancel": "cancel",
        "topic": "add item",
        "topicType": "str",
        "splitLayout": "",
        "className": "",
        "x": 220,
        "y": 660,
                "18dcb329f842183f"
        "id": "18dcb329f842183f",
        "type": "function",
        "name": "ID Generator",
        "func": "msg.payload.id = RED.util.generateId();\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 390,
        "y": 660,
                "821293d40021dc19"
        "id": "821293d40021dc19",
        "type": "change",
        "name": "delete socketid",
        "rules": [
                "t": "delete",
                "p": "socketid",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 640,
        "y": 500,
                "fbe860b501639c1a"
        "id": "fbe860b501639c1a",
        "type": "function",
        "name": "Database",
        "func": "let db = context.get('db');\nif(db === undefined){\n    db = [];\n}\nswitch(msg.topic){\n    case 'add item':\n        msg.payload.timestamp = new Date().toISOString();\n        db.push(msg.payload);\n        context.set('db', db);\n        msg.payload={\n            command:\"addRow\",\n            arguments: [\n                [\n                    msg.payload\n                ],\n                false //false = add on end of list\n            ],\n            returnPromise: true\n        }\n        break;\n    case 'build table':\n        msg.payload={\n            command:\"setData\",\n            arguments: [\n                db\n            ],\n            returnPromise: false\n        }\n        break;\n    case 'clear all':\n        db = [];\n        context.set('db', db);\n        msg.payload={\n            command:\"setData\",\n            arguments: [\n                db\n            ],\n            returnPromise: false\n        }\n        break;\n}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 900,
        "y": 500,
                "35571d7bd35ac114",
                "31731e53875dacf5"
        "id": "35571d7bd35ac114",
        "type": "debug",
        "name": "DATABASE",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1290,
        "y": 500,
        "id": "f18a891c4099b790",
        "type": "switch",
        "property": "topic",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "build table",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 1370,
        "y": 220,
                "4d8aebc1b773d32e"
        "id": "4d8aebc1b773d32e",
        "type": "change",
        "rules": [
                "t": "delete",
                "p": "ui_control",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1400,
        "y": 280,
                "fbe860b501639c1a"
        "id": "d04cb83acc2064af",
        "type": "ui_group",
        "name": "Database",
        "tab": "635ba43dc8d01298",
        "order": 2,
        "disp": true,
        "width": "20",
        "collapse": false,
        "className": ""
        "id": "21028a285361e1fc",
        "type": "ui_group",
        "name": "Input",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "635ba43dc8d01298",
        "type": "ui_tab",
        "name": "example ui-table",
        "icon": "track_changes",
        "order": 1,
        "disabled": false,
        "hidden": false
