Heya folks
I have a project underway which will read sensor values and write to a CSV file. So far with 1 sensor I managed to add a timestamp and value to the file in CSV format with each read. I think in order to be most efficient it would be best to red all 6 sensors consecutively (modbus), update an array, write to CSV, repeat. This needs to be done as fast as possible. Essentially 1 timestamp and then the 6 sensor values comma seperated. Have only added 2 sensors at the moment
I suck and am a complete Noob at java script. Any push in the right direction would be of great help. What I've done so far is prob quite easy to understand, so hoping someone could have a quick look.
Thanks!
[{"id":"4d95c064.56bc5","type":"modbus-flex-getter","z":"fb27fd6.2ca3f","name":"test","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"daab589a.cd8e08","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":650,"y":340,"wires":[["511817c3.98bf08"],[]]},{"id":"5fca0e71.449cb","type":"function","z":"fb27fd6.2ca3f","name":"function","func":"msg.payload = { \n 'fc': 4, \n 'unitid': 1, \n 'address': 1010, \n 'quantity': 2 \n} ;\nreturn msg;\n","outputs":1,"noerr":0,"x":500,"y":340,"wires":[["4d95c064.56bc5"]]},{"id":"511817c3.98bf08","type":"modbus-response","z":"fb27fd6.2ca3f","name":"","registerShowMax":20,"x":890,"y":380,"wires":[]},{"id":"46ee83e8.c042ac","type":"debug","z":"fb27fd6.2ca3f","name":"","active":true,"console":"false","complete":"payload","x":870,"y":340,"wires":[]},{"id":"5673c892.5d8d58","type":"function","z":"fb27fd6.2ca3f","name":"payload","func":"msg.payload = { value: 0 , 'fc': 6, 'unitid': 1, 'address': 1010 , 'quantity': 1 }; return msg","outputs":1,"noerr":0,"x":500,"y":100,"wires":[["3ffcdcbb.fa5c44"]]},{"id":"3ffcdcbb.fa5c44","type":"modbus-flex-write","z":"fb27fd6.2ca3f","name":"Auto Range Off","showStatusActivities":false,"showErrors":false,"server":"daab589a.cd8e08","x":680,"y":100,"wires":[["be36ee78.71b1e"],[]]},{"id":"be36ee78.71b1e","type":"modbus-response","z":"fb27fd6.2ca3f","name":"","registerShowMax":20,"x":890,"y":100,"wires":[]},{"id":"7ee1a410.aae57c","type":"comment","z":"fb27fd6.2ca3f","name":"Set Auto Range To Off","info":"Specifies whether automatic range selection is used\n0 – the measurement range written to the RangeRegister is used for UV value\nacquirement\n1 – the sensor selects the measurement range automatically. If set, the RangeRegister\nwill be read only. After starting the sensor the AutoRangeRegister is set to 1.´ ","x":260,"y":60,"wires":[]},{"id":"a864fe69.12a84","type":"function","z":"fb27fd6.2ca3f","name":"payload","func":"msg.payload = { value: 4 , 'fc': 6, 'unitid': 1, 'address': 1011 , 'quantity': 1 }; return msg","outputs":1,"noerr":0,"x":500,"y":220,"wires":[["47d8297e.06e058"]]},{"id":"47d8297e.06e058","type":"modbus-flex-write","z":"fb27fd6.2ca3f","name":"Set Range","showStatusActivities":false,"showErrors":false,"server":"daab589a.cd8e08","x":670,"y":220,"wires":[["2ceec987.77e3e6"],[]]},{"id":"2ceec987.77e3e6","type":"modbus-response","z":"fb27fd6.2ca3f","name":"","registerShowMax":20,"x":890,"y":220,"wires":[]},{"id":"c057ae0f.ebe7a","type":"comment","z":"fb27fd6.2ca3f","name":"Set Range Register To Pre-defined Range","info":"Second Number:\n0 – reserved\n1 – range 1 (highest sensitivity)\n2 – range 2\n3 – range 3\n4 – range 4\n…","x":320,"y":180,"wires":[]},{"id":"a1d6ac1d.b4436","type":"comment","z":"fb27fd6.2ca3f","name":"Read Range Register Settings","info":"First Number:\n0 = Custom setting written in following node\n1 = Auto - Sensor selects\n\nSecond Number:\n0 – reserved\n1 – range 1 (highest sensitivity)\n2 – range 2\n3 – range 3\n4 – range 4\n…","x":280,"y":300,"wires":[]},{"id":"305daf6e.650b5","type":"modbus-flex-getter","z":"fb27fd6.2ca3f","name":"Get UV","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"daab589a.cd8e08","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":640,"y":520,"wires":[["ed72ec53.2ef5b","ed72baf.7f76548","36c0fcd1.3aff54"],["1fd33e83.bba581"]]},{"id":"777665c0.38b99c","type":"inject","z":"fb27fd6.2ca3f","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":320,"y":520,"wires":[["b38adfe9.8ee28","a180f114.be998"]]},{"id":"b38adfe9.8ee28","type":"function","z":"fb27fd6.2ca3f","name":"function","func":"msg.payload = { \n 'fc': 3, \n 'unitid': 1, \n 'address': 1000, \n 'quantity': 2 \n} ;\nreturn msg;\n","outputs":1,"noerr":0,"x":480,"y":520,"wires":[["305daf6e.650b5"]]},{"id":"ed72ec53.2ef5b","type":"modbus-response","z":"fb27fd6.2ca3f","name":"","registerShowMax":20,"x":870,"y":560,"wires":[]},{"id":"36c0fcd1.3aff54","type":"debug","z":"fb27fd6.2ca3f","name":"","active":true,"console":"false","complete":"payload","x":850,"y":520,"wires":[]},{"id":"2fb7ea7f.9467e6","type":"comment","z":"fb27fd6.2ca3f","name":"Read UV Range Registers","info":"","x":270,"y":420,"wires":[]},{"id":"65c0f113.6a59a","type":"inject","z":"fb27fd6.2ca3f","name":"","topic":"Startup","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"x":130,"y":100,"wires":[["6e81187b.4de8e8"]]},{"id":"3f3d1804.6bf9c8","type":"delay","z":"fb27fd6.2ca3f","name":"","pauseType":"delay","timeout":"250","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":330,"y":220,"wires":[["a864fe69.12a84","d88af0de.d7ce5"]]},{"id":"d88af0de.d7ce5","type":"delay","z":"fb27fd6.2ca3f","name":"","pauseType":"delay","timeout":"250","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":330,"y":340,"wires":[["5fca0e71.449cb"]]},{"id":"6e81187b.4de8e8","type":"delay","z":"fb27fd6.2ca3f","name":"","pauseType":"delay","timeout":"250","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":330,"y":100,"wires":[["5673c892.5d8d58","3f3d1804.6bf9c8"]]},{"id":"ed72baf.7f76548","type":"split","z":"fb27fd6.2ca3f","name":"","splt":"\\n","spltType":"str","arraySplt":"1","arraySpltType":"len","stream":false,"addname":"","x":470,"y":640,"wires":[["41c5b592.1698cc"]]},{"id":"41c5b592.1698cc","type":"switch","z":"fb27fd6.2ca3f","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":640,"wires":[[],["ebfc77e0.ea0c18"]]},{"id":"7fd901bc.d02f6","type":"csv","z":"fb27fd6.2ca3f","name":"","sep":",","hdrin":true,"hdrout":false,"multi":"mult","ret":"\\n","temp":"time, payload","skip":"0","x":1030,"y":640,"wires":[["c9135c11.57caf"]]},{"id":"ebfc77e0.ea0c18","type":"change","z":"fb27fd6.2ca3f","name":"","rules":[{"t":"set","p":"object","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":640,"wires":[["af39f313.4f3ff"]]},{"id":"c9135c11.57caf","type":"file","z":"fb27fd6.2ca3f","name":"\\log.csv","filename":"log.csv","appendNewline":false,"createDir":true,"overwriteFile":"false","x":1160,"y":640,"wires":[[]]},{"id":"af39f313.4f3ff","type":"function","z":"fb27fd6.2ca3f","name":"javascript","func":"var date;\ndate = new Date();\ndate = (date.getFullYear() + '-' + ('00' + (date.getMonth()+1)).slice(-2) + '-' + ('00' + date.getDate()).slice(-2) + ' ' + ('00' + date.getHours()).slice(-2) + ':' + ('00' + date.getMinutes()).slice(-2) + ':' + ('00' + date.getSeconds()).slice(-2));\npayload = {\"time\":date, \"payload\":msg.object};\nmsg.payload=payload;\nreturn msg;","outputs":1,"noerr":0,"x":900,"y":640,"wires":[["7fd901bc.d02f6","38098473.1125bc"]]},{"id":"38098473.1125bc","type":"debug","z":"fb27fd6.2ca3f","name":"","active":true,"console":"false","complete":"payload","x":1070,"y":580,"wires":[]},{"id":"1e95de21.ba8032","type":"function","z":"fb27fd6.2ca3f","name":"function","func":"msg.payload = { \n 'fc': 3, \n 'unitid': 2, \n 'address': 1000, \n 'quantity': 2 \n} ;\nreturn msg;\n","outputs":1,"noerr":0,"x":480,"y":740,"wires":[["d444efbe.8f1"]]},{"id":"a180f114.be998","type":"delay","z":"fb27fd6.2ca3f","name":"","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":330,"y":740,"wires":[["1e95de21.ba8032"]]},{"id":"d444efbe.8f1","type":"modbus-flex-getter","z":"fb27fd6.2ca3f","name":"Get UV","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"daab589a.cd8e08","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":640,"y":740,"wires":[["d224553f.7df358","c7366315.74594","6dd70ef6.9477f"],[]]},{"id":"8f5ba873.372ab8","type":"change","z":"fb27fd6.2ca3f","name":"","rules":[{"t":"set","p":"object","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":840,"wires":[[]]},{"id":"c2d7d067.01bcb","type":"switch","z":"fb27fd6.2ca3f","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":840,"wires":[[],["8f5ba873.372ab8"]]},{"id":"d224553f.7df358","type":"split","z":"fb27fd6.2ca3f","name":"","splt":"\\n","spltType":"str","arraySplt":"1","arraySpltType":"len","stream":false,"addname":"","x":470,"y":840,"wires":[["c2d7d067.01bcb"]]},{"id":"c7366315.74594","type":"debug","z":"fb27fd6.2ca3f","name":"","active":true,"console":"false","complete":"payload","x":850,"y":740,"wires":[]},{"id":"6dd70ef6.9477f","type":"modbus-response","z":"fb27fd6.2ca3f","name":"","registerShowMax":20,"x":870,"y":780,"wires":[]},{"id":"1fd33e83.bba581","type":"debug","z":"fb27fd6.2ca3f","name":"","active":true,"console":"false","complete":"payload","x":1170,"y":480,"wires":[]},{"id":"710889.f0c52778","type":"comment","z":"fb27fd6.2ca3f","name":"Change Function node to set Unit-ID. Leave Unit-ID blank in server setup","info":"","x":440,"y":460,"wires":[]},{"id":"a90a598a.3eecc8","type":"comment","z":"fb27fd6.2ca3f","name":"Next try to add values of sensor 2 into the CSV file.. See how fast can be written. OR read all 6 sensors, write to array then update CSV with 1 timestamp","info":"testing testing","x":660,"y":940,"wires":[]},{"id":"daab589a.cd8e08","type":"modbus-client","z":"","name":"modbus","clienttype":"serial","bufferCommands":false,"stateLogEnabled":false,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyS2","serialType":"RTU-BUFFERD","serialBaudrate":"19200","serialDatabits":"8","serialStopbits":"1","serialParity":"even","serialConnectionDelay":"1","unit_id":"","commandDelay":"1","clientTimeout":"1000","reconnectTimeout":"1000"}]
