Hi
As it is visible in the image below I have an array of 26 values which I want to send it into MySQL dB , Under voltage Colum I have 26 rows , one value at each row , and incoming data is from ignition edge and every time the value is updated the same should be updated in dB
can anybody help me with this
PFA Flow
"id": "d9f3645e862cc528",
"type": "tab",
"label": "Flow 4",
"disabled": false,
"info": "",
"env": []
"id": "4a9707e1946312fe",
"type": "inject",
"z": "d9f3645e862cc528",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 180,
"y": 100,
"ddb651b2d17aee2d"
"id": "33d158d4f77b8056",
"type": "debug",
"name": "#0C416B",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 640,
"y": 160,
"id": "ddb651b2d17aee2d",
"type": "ignition-tag-read",
"server": "fbd184d1ad1deaf1",
"value": "",
"valueType": "msg.payload",
"tagPath": "[edge]1/Devices/1/LPC1/PSUI26",
"x": 260,
"y": 200,
"3fb8f86d2606db16"
"id": "3fb8f86d2606db16",
"type": "function",
"func": "msg.payload = msg.payload.ignitionResult.value;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 180,
"3c68006.976b7",
"33d158d4f77b8056"
"id": "3c68006.976b7",
"type": "template",
"name": "build SQL",
"field": "topic",
"fieldType": "msg",
"format": "sql",
"syntax": "mustache",
"template": "update lpc set voltage = +msg.payload[0]+ , current =15 where powersupply = 'PSU-01'\n",
"output": "str",
"x": 120,
"y": 320,
"821e4c644258ca35"
"id": "821e4c644258ca35",
"type": "mysql",
"mydb": "687ec5a6f3f680be",
"x": 300,
"y": 320,
"id": "871339a6bdeec81d",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"x": 650,
"y": 220,
"id": "3a1229cc4f2c6d63",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 650,
"y": 280,
"id": "bf4c86b5516a9a0a",
"type": "inject",
"name": "Payload value",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]",
"payloadType": "json",
"x": 130,
"y": 40,
"id": "fbd184d1ad1deaf1",
"type": "ignition-server",
"hostname": "192.168.1.21",
"port": "8088",
"ssl": false,
"tls": "",
"defaultTagProvider": "edge",
"name": ""
"id": "687ec5a6f3f680be",
"type": "MySQLdatabase",
"host": "192.168.1.147",
"port": "3306",
"db": "ohmiumnodered",
"tz": "",
"charset": "UTF8"
