Sending/Streaming Sounds to Apple Airplay Devices
in our flat we're using different Apple Airplay devices, for example Apple TV or Airport Express. Is there a way to stream a sound signal to those devices via node-red?
I'm looking for the possibility of sending, for example, an acoustic alarm signal or, in a further step, a sound file or a radio stream.
Does there exist an extension, which I could use therefore?
I would be grateful about every kind of help, because I'm still a newbie in node-red stuff.
Thanks in advance and best regards - Daniel
did you try a google search 'node-red airplay'?
Not sure if any hits will help you but it is a place to start your research.
