i'm using ui-template node
[{"id":"2f8d264e.315b5a","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"168ffcdf.49fec3","type":"ui_template","z":"2f8d264e.315b5a","group":"7df6c9e4.2fe848","name":"","order":1,"width":"0","height":"0","format":"\n<!DOCTYPE html>\n<html>\n<head>\n<style>\n/* This stylesheet sets the width of all images to 100%: */\nimg {\n width: 100%;\n height: 55%;\n}\n</style>\n</head>\n<body>\n<img id=\"lightz\" src=\"https://www.edrawsoft.com/templates/images/living-room-design-plan.png\" alt=\"Pic\" width=\"649\"\nheight=\"422\" usemap=\"#Test\">\n\n<map name=\"Test\">\n <area shape=\"circle\" coords=\"264,28,7\" alt=\"light1\" onclick=\"myFunction()\">\n <area shape=\"circle\" coords=\"263,168,7\" alt=\"light2\" href=\"https://www.youtube.com/\">\n</map>\n\n<script>\nvar x=0;\n\nfunction myFunction() {\n if(x===0){\n alert(\"Light is ON!\");\n document.getElementById('lightz').src='https://i.ibb.co/WcwbWKf/2.png';\n x =1 ;}\n else\n {\n alert(\"Light is OFF!\");\n document.getElementById('lightz').src='https://www.edrawsoft.com/templates/images/living-room-design-plan.png';\n x = 0;\n }\n\n }\n</script>\n</body>\n</html>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":500,"y":280,"wires":[["95330f58.ce5f8","ffae42f8.2632c"]],"outputLabels":["x"]},{"id":"95330f58.ce5f8","type":"debug","z":"2f8d264e.315b5a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":710,"y":240,"wires":[]},{"id":"ffae42f8.2632c","type":"mqtt out","z":"2f8d264e.315b5a","name":"","topic":"","qos":"","retain":"","broker":"961e00a7.0b8a6","x":710,"y":300,"wires":[]},{"id":"7df6c9e4.2fe848","type":"ui_group","z":"","name":"Lights","tab":"bac79aeb.7c1288","order":1,"disp":true,"width":"6","collapse":false},{"id":"961e00a7.0b8a6","type":"mqtt-broker","z":"","name":"","broker":"","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"bac79aeb.7c1288","type":"ui_tab","z":"","name":"Living room","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
