Sequence Check of Booleans
Hello all,
i would need some help on a function to create a sequence check of multiple incomming booleans after each other:
e.g.:
I have 3 booleans that are incomming one after each other:
first message : msg.payload.valueBool = true
second message : msg.payload.valueBool = false
third message = msg.payload.valueBool = true
Based on that i would like to compare these message "sequence" with an defined sequence in a function node.
The function is currently looking like that:
var expectedSequence = [true, false, true];
var currentSequence = [];
function sequenceValidation(msg) {
  var value = msg.payload.valueBool;
  currentSequence.push(value);
  if (currentSequence.length > expectedSequence.length) {
    currentSequence.shift();
  var sequenceCheck = JSON.stringify(currentSequence) === JSON.stringify(expectedSequence);
  msg.payload.sequence_check = sequenceCheck;
  msg.payload.sequence = currentSequence;
newMsg = sequenceValidation(msg);
return newMsg;
Currently the Output looks like this, but the append / push operation to the array is not working and therefore the sequence check does not work:
{"_msgid":"14392d94b3744644","payload":{"valueBool":false,"sequence_check":false,"sequence":[false]},"topic":""}
If they are three separate messages you will need to join or store them in context storage
e.g context
let expectedSequence = [true, false, true];
let currentSequence = context.get("currentSequence") || [];
currentSequence.push(msg.payload.valueBool);
currentSequence = currentSequence.slice(-expectedSequence.length)
let sequenceCheck = currentSequence.join("") === expectedSequence.join("");
context.set("currentSequence", currentSequence)
Existing solution on forum...
