Serial filter separates the outputs into different outputs
I read the following Strings from an RS232 but I would like to have each String in a separate output does anyone have an idea how to do it?
Thanks so much
Hi @maxino101578
This will work,
But someone may have a cleaner way.
Connect your serial output to the join node
I have used 5 as the number of outputs on the function node and set 5 as the number of message parts on the join node based on your screenshot
We then split the batch into 5 outputs
[{"id":"31bdde550a6cf2b6","type":"function","z":"e7094296.ee2ea","name":"function 1","func":"const L0 = {payload:msg.payload[0]}\nconst L1 = {payload:msg.payload[1]}\nconst L2 = {payload:msg.payload[2]}\nconst L3 = {payload:msg.payload[3]}\nconst L4 = {payload:msg.payload[4]}\n\nreturn [L0,L2,L2,L3,L4]","outputs":5,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":680,"wires":[["71e1b5e52fd2e8d4"],[],[],[],[]]},{"id":"71e1b5e52fd2e8d4","type":"debug","z":"e7094296.ee2ea","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":860,"y":660,"wires":[]},{"id":"704ba4b9cab152cc","type":"join","z":"e7094296.ee2ea","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"5","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":430,"y":680,"wires":[["31bdde550a6cf2b6"]]}]
Hi Marco, thank you very much for your reply, this is the result
I try to always have the same result for the first issue
I would like to have a separate output for each single value, any ideas?
try the OUT -> split node, to slice it up into separate values, instead of \n try \t as it appears to be a tab separated string.
Thanks a lot bakman2, I tried but the result is the same
can you copy the output of one of those strings (using the copy icon in the debug window) and paste it here between 3 backticks ? (or use the </> icon in the editor here).
``` output ```
Copying with debug icon, the result is this:
payload
This is what's in the window:
I think @bakman2 meant Copy Valuet as described in this, which is one of our canned replies:
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
That should give you basically the same info as in the screenshot, but in a less ambiguous form.
Thanks a lot Colin I used the steps you say, but my data that I want to split is on the same line but I want to separate it.
One value, one output
Yes we are aware, but if you paste the output here in text, we can possibly help you, screenshots don't work.
You could use a function node after the the buffer array with something like:
const data = msg.payload  // assuming this is the input array
data.forEach(e=>{
    let tmp = e.replace(/\s\s+/g, ' ').split(' ').pop()
    node.send({payload:parseFloat(tmp)})
return null
Sorry bakman2 below the result:
[" 35.0 37.0 27 28 33\r\n","\r\n","SOC: 80.608A/h LEM: - 17.412A Vmed: 3.550V Vtot: 53.239V\r\n","Vmin: 3.492V ==> 9 Vmax: 3.589V ==> 7\r\n","TMax: 25.3 TMin: 19.5 Tint: 33.0 TdMax: 28.0 TcMax: 37.0\r\n","Ricarica 61% + Equi\r\n"]
The solution from this info
