Dear all.
I have a piece of code that is quite stubborn and I can't seem to find the problem.
I am using an emergency ESP8266 as my nano showed the white-magic-mist-of-disappointment
The code:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BMP3XX.h"
#include <ArduinoJson.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BMP3XX bmp3xx;
void setup() {
Serial.begin(115200);
bmp3xx.begin_I2C(0x76);
bmp3xx.setTemperatureOversampling(BMP3_OVERSAMPLING_4X);
bmp3xx.setPressureOversampling(BMP3_OVERSAMPLING_4X);
bmp3xx.setIIRFilterCoeff(BMP3_IIR_FILTER_COEFF_3);
bmp3xx.setOutputDataRate(BMP3_ODR_50_HZ);
void loop() {
StaticJsonDocument<128> doc;
bmp3xx.performReading();
doc["Temperature bmp3xx"] = bmp3xx.temperature;
doc["Pressure bmp3xx"] = bmp3xx.pressure / 100.0;
String jsonString;
serializeJson(doc, jsonString);
Serial.println(jsonString);
Serial.println();
delay(1000);
The problem:
Why does this happen?
Same problem with:
#include <Wire.h>
#include <Adafruit_BME680.h>
Adafruit_BME680 bme680; // Create an instance of the BME680 sensor
void setup() {
Serial.begin(115200); // Initialize serial communication
bme680.begin(); // Initialize the BME680 sensor
// Configure sensor settings
bme680.setTemperatureOversampling(BME680_OS_4X);
bme680.setHumidityOversampling(BME680_OS_4X);
bme680.setPressureOversampling(BME680_OS_4X);
bme680.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme680.setGasHeater(320, 150);
void loop() {
bme680.performReading(); // Perform sensor reading
// Create a JSON object to hold the sensor values
StaticJsonDocument<256> jsonDoc;
// Create an object to hold the bme680 sensor values
JsonObject bme680Obj = jsonDoc.createNestedObject("bme680");
bme680Obj["temperature"] = bme680.temperature;
bme680Obj["pressure"] = bme680.pressure / 100.0;
bme680Obj["humidity"] = bme680.humidity;
bme680Obj["gas"] = bme680.gas_resistance / 1000.0;
// Serialize the JSON object to a string
String jsonString;
serializeJson(jsonDoc, jsonString);
// Send the JSON string through serial
delay(1000); // Delay for 1 second before the next reading
This is my debug:
"nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�nb�nl`�rl�l��l�n..."
I grabbed my Arduino 2560 mega pro and uploaded the code. This works like a charm:
#include <Wire.h>
#include "Adafruit_MPRLS.h"
Adafruit_MPRLS mpr;
void setup() {
// Initialize the sensors
bme680.begin();
mpr.begin();
// Configure BME680 sensor settings
// Configure BMP3XX sensor settings
void loop() {
StaticJsonDocument<512> jsonDoc;
// Read BME680 sensor values
// Read BMP3XX sensor values
JsonObject bmp3xxObj = jsonDoc.createNestedObject("bmp3xx");
bmp3xxObj["temperature"] = bmp3xx.temperature;
bmp3xxObj["pressure"] = bmp3xx.pressure / 100.0;
// Read MPRLS sensor values
float pressure_hPa = mpr.readPressure();
JsonObject mprlsObj = jsonDoc.createNestedObject("mprls");
mprlsObj["pressure_hPa"] = pressure_hPa;
mprlsObj["pressure_PSI"] = pressure_hPa / 68.947572932;
String jsonString;
Could it be that my ESP8266 cannot use this code?
WBr:
This is my debug:
"nb�nl
looks like an incorrect comms config at first glance. Are you certain you have the right settings for the comms (stop bits, baud, parity etc)
Yes! Because it works on the arduino 2560 mega pro!
Colin
8 June 2023 14:43
5
Well if the code runs correctly in one device but not another then it isn't a node red problem. It must be the device.
True, but Isn’t it a common thing to use USB to send data from a microcontroller to pi?
(Except the wifi/mqtt functionality ofc)
Colin
8 June 2023 16:09
7
Yes, but you said it works on the other device.
Colin
8 June 2023 16:11
8
But I thought you were using serial, not usb.
I was today years old when i learned that this is different.
But yes, usb!
I found the problem....
I used a different ESP8266 board library in Arduino IDE
The "Generic ESP8266 module" (wrong)
Turns out NodeMCU 1.0 is the correct version
Colin
8 June 2023 18:04
11
I think you mean serial via a serial to usb adaptor (which may be built into the device). Otherwise you would not be seeing the serial settings.
Again, though, if it works on one device and not on another then it must be differences in the device.
