how can i format the ServerTime (Now) for InfluxDB2 ?
It needs the RFC3339 Format.
(new Date()).toISOString()
won´t work, i get an Error from InfluxDB Node "bad Timestamp"
Isnt InfluxDB timestamps in micro seconds unless you tell it otherwise?
Try using Date.now() * 1000) instead of passing a string.
Did you try just passing the influx node the Date object?
Also, don't forget that if you are passing in the current time then you generally don't need to do that, influx will default to the current time.
Yes i just passed it, but before i used InlfuxDB 1.8, now it´s Version 2.5 with Flux language, and the Flux _time _start and _stop is more variable then before.
So i want to use my own Timestamp in a variable, not the one of InfluxDB
OK, I was just checking in case you were not aware of the options. I have not moved to Influx 2 yet.
