I'm implementing session management in my Node-RED ui_base.js file and handling user sessions using WebSocket cookies. Here are the challenges and requirements I'm facing:
- Redirect to Login on Session Expiry:
- I've implemented session handling in the
onConnectionfunction. - When no cookies are found or the session ID is invalid/expired, I disconnect the socket.
- On page reload, users are redirected to the login page, but I also want them to be redirected dynamically when their session expires or is destroyed, without requiring a page reload.
- Prevent Widget Interaction Without Session:
- When a user's session expires, I need to prevent interaction with UI widgets like sliders, gauges, or other inputs.
- Currently, the widget interactions send input payloads to the server, which I want to avoid for expired sessions.
- Dynamic Redirection on UI Events:
- When users perform actions like changing pages or interacting with widgets, if their session is invalid, I need to:
- Prevent the action or input payload from being processed.
- Redirect them to the login page dynamically.
Questions:
- How can I implement dynamic redirection to the login page during user interaction (e.g., widget input, page change) without requiring a browser reload?
- What is the best approach to control or block widget interactions when the session is invalid or expired?
- Are there existing best practices or middleware in Node-RED for session-based user interaction control?
* on connection handler for SocketIO
* @param {Socket} socket socket.io socket connecting to the server
function onConnection(socket) {
// Record mapping from connection to the ui-base node
socket._baseId = node.id;
// Handle cookies
let cookies = socket.request.headers.cookie;
console.log("****************cookies in socket: ", cookies);
if (!cookies) {
console.log("No cookies found, closing socket connection.");
//socket.emit('redirect', '/login.html'); // Emit the redirect event with the login page URL
socket.disconnect(true); // Disconnect the WebSocket
return;
// node.connections[socket.id] = socket // store the connection for later use
uiShared.connections[socket.id] = socket // store the connection for later use
emitConfig(socket)
// clean up then re-register listeners
// cleanupEventHandlers(socket)
// setup connections, and fire any 'on('connection')' events
setupEventHandlers(socket, true)
Any guidance or code samples to address these issues would be greatly appreciated!
