Set a logo in the title bar?
Hi all,
Did any of you manage to do this? If not, I have some code which could help you out. Please have a look at this flow:
[{"id":"42b8d6d1.fc68e8","type":"ui_template","z":"7e61871d.8d71a8","group":"feabd600.f71b28","name":"Logo / Clock","order":0,"width":0,"height":0,"format":"<script id=\"clockScript1\" type=\"text/javascript\">\n    var clockInterval;\n    $(function () {\n        if (clockInterval) return;\n\n        //add logo\n        var div1 = $('<div/>');\n        var logo = new Image();\n\n        logo.src = '/logo.png'\n        logo.height = 45;\n        div1[0].style.margin = '10px auto';\n\n        div1.append(logo);\n\n        //add clock\n        var div2 = $('<div/>');\n        var p = $('<p/>');\n\n        div2.append(p);\n        div2[0].style.margin = '5px';\n\n        function displayTime() {\n            p.text(new Date().toLocaleString());\n        }\n        \n        clockInterval = setInterval(displayTime, 1000);\n\n        //add to toolbar when it's available\n        var addToToolbarTimer;\n        \n        function addToToolbar() {\n            var toolbar = $('.md-toolbar-tools');\n            \n            if(!toolbar.length) return;\n            \n            toolbar.append(div1);\n            toolbar.append(div2);\n            clearInterval(addToToolbarTimer);\n        }\n        addToToolbarTimer = setInterval(addToToolbar, 100);\n    });\n</script>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"global","x":610,"y":220,"wires":[[]]},{"id":"feabd600.f71b28","type":"ui_group","z":"","name":"Default","tab":"fb98fdb9.b193a","order":1,"disp":false,"width":"24","collapse":false},{"id":"fb98fdb9.b193a","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
You have to have the image you are wanting to display on the toolbar, on your local machine. Please refer to this page in the google group for some more info on this. It is about changing the htttp static in the settings.js file.
Adding images to the ui
Please refer to where Guilherme replies to myself.
And then use this link for some help with the http static part I was talking about: httpstatic
Hope this helps,
