hello all, I'm working with svg node, I use "update_style/set_style" or "update atributte/set_atributte" commands to change the color of an object created in the same node, and it works fine, but I noticed that when reloading the page the change disappears or when I change the dashboard tab.
My question is, is there a way to make the change permanent?
You can use the ui-control node to detect new page access / page refresh and re-supply the changes & updates.
