Set Linux shell environment variable
in Node Red I need to set a Linux Shell environment variable, for instance SPEAKVOL=10
I tried everything, also to create a shell file:
#!/bin/sh
export SPEAKVOL=$1
and then adding an exec node with the command
source name_of_above_file.sh
but it is not working.
How can I do? Please help!
Thanks,
Dan
You could set the environment variable in the settings file as explained in below link.
from my understanding each shell instance has a unique set of environments.
If you run it under a bash script, when the shell ends after the script has run the variable dies with it
I would put the command you want to run in the second exec node into the script you want to source and just launch that script in a single exec node. Keeps things self-contained
Environmental variables are not global, but they can look that way because a "standard" set is generally created in various .bashrc and/or .profile files that are highly system dependent and loaded when a new login shell is created and possibly a different or null set when a non-interactive (not attached to a "terminal") shell is launched.
I try to avoid using environmental variables whenever possible.
