Set Object name from msg.topic?
Hi All, I'm banging my head with this and I'm sure the answer is obvious but I can't find the search term or work it out.
I'm pinging a series of devices with the ping node I want to create a message object that contains device:ping_value
All the info is in there as msg.topic contains the device name
And msg.payload contains the ping value
sadly this doesn't work.
msg.payload = {msg.topic:msg.payload};
so how can I combine the two?
At present I'm making a bunch of function nodes that are manually setting the object name.
msg.payload = {
    Rpi2White:msg.payload
Something like
let value = msg.payload
msg.payload = {}
msg.payload[msg.topic] = value
Perfect thank you so very much.
