Set payload to first occurence of certain key/value in array
Flow:
        "id": "1c81edcb527606e1",
        "type": "inject",
        "z": "1151076dd0552f2d",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "[{\"status\":\"DELIVERED\",\"dateIso\":\"2023-03-03T10:26:00+01:00\"},{\"status\":\"HANDED_IN\",\"dateIso\":\"2023-02-24T14:10:50+01:00\"},{\"status\":\"DELIVERED\",\"dateIso\":\"2023-01-26T12:42:50+01:00\"},{\"status\":\"IN_TRANSIT\",\"dateIso\":\"2023-01-23T19:28:08+01:00\"},{\"status\":\"PRE_NOTIFIED\",\"dateIso\":\"2023-01-19T09:01:08+01:00\"}]",
        "payloadType": "json",
        "x": 1010,
        "y": 1260,
                "6660c65d96d28d5c"
        "id": "6660c65d96d28d5c",
        "type": "debug",
        "name": "debug 28",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1140,
        "y": 1260,
This array has 5 items where 0 is the newest and 4 is the oldest.
As you can see, both item 0 and 2 has a status of DELIVERED.
I want to do two things:
  1. First I want to look for any occurence of DELIVERED in the array. If the array contains a status of DELIVERED in any of the items, the message shall pass through a switch node.
  2. Then, I want to set the payload to the array item with the oldest occurence of DELIVERED. So in this case, the payload should be set to {"status":"DELIVERED","dateIso":"2023-01-26T12:42:50+01:00"} because item 2 is the oldest where DELIVERED appears.
How would I go on about this? This is just an example array - the array may have 10 items where every other item has DELIVERED, for example.
Thanks!
Though I'm sure you could use a JSONata expression to do this, I'd use a function node.
  1. get the length of the array,
  2. set a variable 'oldest_date' to 0
  3. use a 'For loop' to loop thru each of the items and search the status for delivered.
  4. If found, compare the data of that occurrence to the 'oldest_date'
  5. if older, store that date.
  6. when you exit the loop, you will have the oldest data to do with what you want.
I know its not low-code - but all can be done in 1 function node.
/* Filter to DELIVERED */
const FilterToDelivered = msg.payload.filter((ArrayEntry) => ArrayEntry.status === 'DELIVERED');
/* Only continue if we have DELIVERED */
if (FilterToDelivered.length > 0){
    /* Get Min Timestamp of DELIVERED */
    const MinTimeStamp = Math.min(...FilterToDelivered.map((ArrayEntry) => Date.parse(ArrayEntry.dateIso)))
    /* Now set payload to oldest - using the min Timestamp we got above */
    msg.payload = FilterToDelivered.find((ArrayEntry) => Date.parse(ArrayEntry.dateIso) === MinTimeStamp)
    return msg
Hmm, when implementing this into my flow I get some issues.
The actual path to the object with the array is:
msg.payload.consignmentSet[0].packageSet[0].eventSet
So I changed the code to this:
const FilterToDelivered = msg.payload.consignmentSet[0].packageSet[0].eventSet.status.filter((ArrayEntry) => ArrayEntry.status === 'DELIVERED');
But then I get the following error:
TypeError: Cannot read properties of undefined (reading 'filter')
Should be
const FilterToDelivered = msg.payload.consignmentSet[0].packageSet[0].eventSet.filter((ArrayEntry) => ArrayEntry.status === 'DELIVERED');
You were trying to call filter on a property, not the array its self
filter should be applied on an array object, and you provide a delegate to do the filtering:
In our case the item in the array (I called it ArrayEntry) its status property is DELIVERED
Thanks!
Any way to give the function node 2 outputs, where the message is sent to output 1 if DELIVERED exists, and output 2 if it does not? Like a switch node.
Set the function node properties to have 2 outputs (setup tab)
Then...
    return [msg, undefined] /* Top output */
} else {
    return [undefined, msg] /* Bottom output */
Anymore, you probably want to start using the built in nodes :sweat_smile:
Thank you so much for the help, I have achieved what I want now :slight_smile:
Is it always the last 'delivered' entry in the array that you want? If so there is a simpler solution using findLast()
I always want the first one, not the last one.
In that case one can use find()
Something like (untested)
msg.payload = msg.payload.consignmentSet[0].packageSet[0].eventSet.find(
if (typeof msg.payload !="undefined") {
  return msg
[Edit] Fixed some typos above
To extend on the simpler approach by @Colin and to retain the ability to output to a 2nd pin if non are delivered.
const FirstDelivered = msg.payload.consignmentSet[0].packageSet[0].eventSet.find((ArrayEntry) => ArrayEntry.status === 'DELIVERED');
if (FirstDelivered !== undefined){
    return [{payload:FirstDelivered}, undefined] /* Top output */
} else {
I cant remember if Javascript arrays are guaranteed order - I'm sure they are.
I think I would marginally prefer that to be
    msg.payload = FirstDelivered
} else {
or even
let answer = []
    answer =  [msg, undefined] /* Top output */
} else {
    answer =  [undefined, msg]                      /* Bottom output */
return answer
I prefer just to have one return at the end. Too many times over many years I have seen code added to a function at the end, forgetting that there has already been a return made earlier in the function, so I have a rule that I never do that, even in a simple case like this.
