I have searched over the forum but not find a solution:
In a template node I know how to get the value from a flow variable defined in a function node ,for example:
Amh_orig_X={{flow."origine_X"}}
works well, but to set a flow variable from a template node ?
The documentation says something like that: {{flow[store].name}}
But what value have to be [store] ? For example, if i wish to store the value "100" in "MyValue" is it:
{{flow[100].MyValue}} ? or {{flow["100"].MyValue}} ? What is the good syntax ?
Thanks for your help !
