Setting properties of a chart that is inside a subflow - HowTo?
How do you modify the properties of chart that exists inside a subflow? I need to create a subflow that has two graphs and two gauges. This subclow will be used at least 10-20 time thus the need to reuse the charts rather than create and maintain 40-80 charts and gauges individually.
These need to have the dashboard group and page properties set so that they can be laid out properly. These properties are not configured with free-form text fields and therefore I cannot use environment variables. Some have drop-down lists and I don't know how to set their value from outside the subflow or in the subflow configuration page.
Is there an example of setting chart and gauge properties from outside the subflow?
Hi and welcome to the forum.
As you are new here, for the first few days you will be limited to how much you can post.
(Though I think you've been told that when you joined.)
Sorry, but the dumbest questions are the ones not asked.
WHY are you putting a chart node in a subflow?
Put all the workings in the subflow, sure. But the chart too?
If you do it this way, the charts can be where ever you want - by editing their details.
The subflows don't need that and so you have an output from the subflow to the chart.
Easier I think that way.
Up to you.
(Just something to share as you are new here.)
There are no RIGHT or WRONG ways to do things. So long as the job gets done.
But from what I've recently .... discovered is I was building all my flows a bad way.
Bad as in they weren't easy to update how they were laid out.
There are two ways to lay out a flow - of which I understand.
1 - the way I was doing it - is where you have the flows grouped into functional blocks where all the workings and (to call it) eye candy mixed up with one another.
2 - a better way - is to go one step further!
Sure, have these blocks, but also keep the workings SEPARATE from the eye candy.
As I just suggested with the subflow.
This way if ever you want to change the WORKINGS of a flow, you just migrate that part to where ever you want.
Then, hook up a few wires to the inputs and some from the workings block to the eye candy part/s.
But: it is just a suggestion.
The main reason for putting the charts in the subflow is that there will be many duplicates of the same gauges and charts but displaying different data from several different sensors. It's just code re-use. Rather than maintain and change the properties of 40 charts and gauges that are all the same, I'd rather have the properties in one location where a change to the segment colors or divisions can be edited once rather than having to edit 40 gauges and charts.
The layout is simple but need to put two charts and two gauges into one group. I have 10-20 groups to create all displaying data from different temperature and moisture sensors.
While I do have the logic for processing the data in a subflow, I was hoping there is a way to define the base properties of a chart and gauge once and then re-use those settings everywhere. I'd be able to update the gauge segments, colors, range once and have affect all of them.
Even if I could just lump the gauges and charts into a subflow by themselves and set the flow up from the data processing subflow to the display subflow would be great. The goal is to not have to maintain 20-40 separate charts and gauges individually when all their settings should be the same except for the page/group settings.
Yes and I can sort of see what you mean and why you are thinking that way.
No offence.
Let's look at it again:
And forgive my poor representation of your edit screen.
This is what it would look like.
(Indulge me)
My way of doing it the flow would look like:
You wouldn't really be losing much space.
AND....
As I said, you then CAN just copy the subflow to where ever you want.
That's the idea but here is what I have so far. I have 7 sensors defined as of now with more on the way.
Only one group of charts and gauges are defined at the moment. Each sensor has a chart and a gauge for both Temp and Humidity. So with the 7 sensors, there will be 28 separate gauges and charts combined that need to sync'd except for the group and possibly page settings. Once I add more sensors, it's going to be nearly impossible to edit all the gauges and charts if I need to make a change and having to edit that many separately is prone to mistakes as well.
Each sensor will have it's own group on the dashboard that looks like this:
What I want to do is put the two charts and two graphs in subflow and just reuse that over and over, only changing the group/and page settings for each subflow. Thereby avoiding having to edit each manually. I'd just edit the subflow and all the sensors settings would sync instantly.
I fully appreciate what you mean.
And I do agree in some ways.
But... the catch being maybe subflows aren't able to support that mode/method.
What you could do - sorry, just suggesting - is this.
On this flow, have all the subflows getting their data, and their associated 4 outputs.
On the outputs, put link out nodes and put all the gauges on ANOTHER flow.
Then you will have a flow of the workings and another of the eye candy.
Yes, a bit more work.
Although not exactly specific to this scenario - as I indicated earlier:
This way keeps the workings separate to the eye candy.
I'm strongly suggesting this because when you get more and more into this it will become evident of the benefits of doing it this/that way.
(Keeping the separate.)
Otherwise you want to update some of the workings and can't easily copy it to other flows/machines (what ever) without all the eye candy being mixed in with it.
This way they are very separate.
Thanks for the ideas. It still doesn't help me when I need to make a change to 28+ charts and gauges. Ideally, I need gauge and chart template or a way to put the repetitive UI elements into a subflow and then reuse that single subflow multiple times, only changing the placement location data. Hm. Doesn't seem like there's a way to do that right now.
Thanks for your help.
I am sure you can send template information to them with no problems.
You set the charts (eye candy) to receive template information.
So you edit 1 subflow, it propagates to all instances and the eye candy receives the templates and adjusts accordingly.
BTW: I am way down the learning scale. There are smarter people here.
Just - at this point - I guess I'm online.
I know it sounds painful what I'm saying.
(I can speak from your side of the coin very well)
But if you take the effort NOW - while you are still VERY NEW to it, I hope it won't enstill (how ever you spell it) bad habits with how you do things.
The suggested way is that all the template stuff is done at another level of the language and so you don't need to worry about it.
It would mean a lot of work inside the subflow, but not really much more than if you do it your way anyway. Just you are moving WHERE the work is done.
Before the eye candy or in the eye candy.
Sorry, I'm using that to make a demarcation line between the two types of nodes.
You have to declare the subflow properties as being of type Config and being group and page.
Just wondering how things are going?
Something else that I would like to mention.
(and of course as soon as I typed that I forgot what it was I was going to say)
Ah!
ui_builder
I have no real experience with it, but it is a whole other level of doing things.
It is part of Node-red.
May be worth looking into it.
I was able to get it to work with @Colin's suggestion. Using config node to set the chart's properties such as group, width, height, etc. It was a little confusing at first but I figured it out. This is something that there should be a YouTube tutorial for since it is very useful but somewhat complicated if you are doing it for the first time.
It's working great now and I have all sensors displaying a chart and gauge for both temp and moisture content.
First you create the config nodes in the flow that point to the chart property you need to have configurable:
Next you set the property in the chart or gauge node to use the property you just created:
Here you can see the subflow that has a chart and two gauges:
And here is the flow that uses the subflow:
The final dashboard page looks like this now and I only have to modify the chart and gauges in the subflow to change all of them.
Thanks to everyone for your help.
Can you share your subflow code and an example of its use.
I have something similar that I want to do with my many temperature sensors. I am currently duplicating everything and I don't like it. Having UI components in a subflow never occurred to me!
You probably only needed to declare 1 env var group (the 3 gauges inside can all pick the same one) (unless i am missing something you are catering for)
Great to hear.
Hope you have luck with future stuff in Node-red.
Here's the code for the flow. This is used in an automated garden watering system. The scheduling has yet to be done but will be based on a daily watering schedule which is skipped if the soil moisture percentage is above a certain amount.
In this case, I am using zigbee2MQTT to read temp and moisture sensor data from 7 sensors. This should be used only as an example of how to put UI elements in a subflow.
The subflow "Process and Chart Data" has one combined chart that displays the last 7 days of historical temperature and soil moisture % and two gauges, one for temp and the other for soil moisture. You create a new instance of the subflow, set the group to a blank or new group in your UI. Changes to the subflow chart or gauges are reflected everywhere rather than having to edit several charts and gauges..
[EDIT]: This flow requires Dashboard 2.0
flows (1).json (31.7 KB)
When importing that JSON, I am getting unknown nodes for the ui-chart and ui-guage.
EDIT: For you switch node consider a function node that sets a target name and use a Link-Call that targets each of your Link-In nodes. It's cleaner and saves a lot of Link-Out nodes
@MyRandomThoughts, I think you need to have Dashboard 2.0 installed to get those ui-chart and ui-guage nodes. I should have mentioned that I am using Dashboard 2.0. The original dashboard's components have an underscore in their names i.e. ui_chart and ui_gauge. While Dashboard 2.0 uses hyphens i.e. ui-chart, etc.
Thanks for the pointer on using a function to send to links. I'll look into that.
I don't think that widgets in subflows works on the old dashboard.
Thanks for the suggestion, I removed the extra two group variables.
