I have a problem setting up a modbus server, hope someone can help me.
I want to use the Raspberry as a Modbus Server.
I want to connect vacuum pumps to the raspberry so that I have a monitor system
Each pump has its own IP address.
Pump 1: IP 129.1.0.25 port 502
Pump 2: IP 129.1.0.26 port 502
up to 6 pumps
The problem now is that the connection is constantly broken between the pumps. is due to the different IP addresses, i Think??
Therefore I think a MODBUS server is the solution for me ?? I hope??
I have already tried something but then the system crashes completely
My question.
How should I configure the modbus server?
which ip address should the raspberry have and which ip the modbus server etc
thank you in advance
