Hello, its been some time since last i was in here.
This time i want to share my latest work.
its a rpi3b with a gas sensor logging the level of volatile organic compunds in the air.
this project is to be installe in a local factory, however, you can use it at home to manage your hvac or what not.
added realtime display on top, and also the possibility for replay whatever it looked like in the data that is logged.
Enjoy ![]()
"id": "6853f0ac528a909d",
"type": "inject",
"z": "edb67b270919ddcd",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": "5",
"topic": "",
"payload": "1",
"payloadType": "str",
"x": 70,
"y": 20,
"dfa00e68a1a1e242"
"id": "dfa00e68a1a1e242",
"type": "exec",
"command": "python3 /home/pi/Sensirion_SGP40-master/example_sgp40_voc_index.py",
"addpay": "",
"append": "",
"useSpawn": "true",
"timer": "",
"winHide": false,
"oldrc": false,
"name": "run_sensor",
"x": 230,
"y": 40,
"a3159d04582037b2"
"id": "a3159d04582037b2",
"type": "function",
"name": "format_data",
"func": "msg = msg.payload.split(\":\").slice(1, 4).map(e => { return { payload: parseFloat(e) } });\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 230,
"y": 100,
"1afdc931c92d6a9a",
"cb51da9339906215",
"26933c4ce1586207"
"id": "1afdc931c92d6a9a",
"type": "ui_chart",
"name": "trend",
"group": "2c6cfd085b3f9f40",
"order": 1,
"width": "18",
"height": "6",
"label": "VOC level 24h",
"chartType": "line",
"legend": "false",
"xformat": "HH:mm:ss",
"interpolate": "bezier",
"nodata": "",
"dot": false,
"ymin": "0",
"ymax": "500",
"removeOlder": "24",
"removeOlderPoints": "",
"removeOlderUnit": "3600",
"cutout": 0,
"useOneColor": false,
"useUTC": false,
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"useDifferentColor": false,
"className": "",
"x": 450,
"y": 140,
"id": "cb51da9339906215",
"type": "function",
"name": "log_data",
"func": "var str = msg.payload;\nmsg.topic = \"INSERT INTO VOCDATA (voc) VALUES ('\" + str +\"')\";\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 240,
"y": 140,
"1033564e0d655f61"
"id": "1033564e0d655f61",
"type": "mysql",
"mydb": "500ed4569796efb2",
"x": 230,
"y": 200,
"id": "23527118c4e86aea",
"type": "ui_date_picker",
"name": "stop",
"label": "To",
"group": "68a6973f444db8dd",
"order": 3,
"width": "5",
"height": "1",
"passthru": false,
"topic": "stop",
"topicType": "str",
"className": "",
"x": 130,
"y": 360,
"102767a995708cc1"
"id": "03081d373fcf0db4",
"name": "start",
"label": "From",
"order": 2,
"width": "5",
"height": "1",
"passthru": false,
"topic": "start",
"topicType": "str",
"className": "",
"x": 130,
"y": 320,
"08822362d0ae7a33"
"id": "08822362d0ae7a33",
"type": "moment",
"topic": "start",
"input": "payload",
"inputType": "msg",
"inTz": "Europe/Amsterdam",
"adjAmount": 0,
"adjType": "days",
"adjDir": "add",
"format": "",
"locale": "en_GB",
"output": "payload",
"outputType": "msg",
"outTz": "Europe/Amsterdam",
"x": 250,
"y": 320,
"6c85e8628292641f"
"id": "102767a995708cc1",
"type": "moment",
"topic": "stop",
"input": "payload",
"inputType": "msg",
"adjAmount": 0,
"adjType": "days",
"adjDir": "add",
"format": "",
"locale": "en_GB",
"x": 250,
"y": 360,
"6c85e8628292641f"
"id": "6c85e8628292641f",
"type": "function",
"name": "sql",
"func": "context.start = context.start || \"2000-01-01\"\ncontext.stop = context.stop || \"2099-01-01\"\ncontext.group = context.group || \"0\"\n\nif (msg.topic == \"start\")\n context.start = msg.payload.slice(0,10) + \"T00:00:00.000Z\";\nif (msg.topic == \"stop\")\n context.stop = msg.payload.slice(0,10) + \"T23:59:59.999Z\";\nif (msg.topic == \"datasource\")\n context.group = msg.payload; \n \n\n\nvar sql = \"\";\nvar outputs = [];\n\n////, curdate(), DATE_FORMAT(TIMESTAMP,' %d/%m %H:%i') AS shortdate\n\n//sql = \"SELECT TIMESTAMP AS x, voc as y from VOCDATA WHERE timestamp BETWEEN '\" + context.start + \"' AND '\"+context.stop+\"' group by timestamp desc\";\nsql = \"SELECT timestamp, voc from VOCDATA WHERE timestamp BETWEEN '\" + context.start + \"' AND '\" + context.stop + \"' group by timestamp desc\";\n\noutputs.push({topic:sql});\n\nmsg.payload = [context.group, context.start, context.stop]\n\nreturn [ outputs ];\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 370,
"y": 340,
"cf1915d0daa3e46c",
"0912aeb92890291f"
"id": "cf1915d0daa3e46c",
"type": "delay",
"pauseType": "delay",
"timeout": "500",
"timeoutUnits": "milliseconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"outputs": 1,
"x": 550,
"y": 280,
"d549ac9c6276d53d"
"id": "d549ac9c6276d53d",
"type": "mysql",
"name": "gaslog",
"x": 530,
"y": 320,
"a6f9a157ec4aa242"
"id": "0912aeb92890291f",
"type": "function",
"name": "empty",
"func": "msg.payload = [];\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 530,
"y": 400,
"41c445ea4ef57e61"
"id": "8656853660fd5247",
"type": "ui_template",
"name": "background/banner/time",
"order": 8,
"width": "0",
"height": "0",
"format": "<style>\n \n body {\n background-image: url(\"/gass.jpg\");\n background-size: 100% 100%;\n }\n md-toolbar {\n background-image: url(\"/logo_banner.png\");\n background-size: 100% 100%;\n }\n</style>\n<script id=\"clockScript\" type=\"text/javascript\">\n var clockInterval;\n $(function () {\n $('#clockScript').parent().hide();\n if(clockInterval) return;\n var toolbar = $('.md-toolbar-tools');\n var div = $('<div/>');\n var p = $('<p/>');\n div.append(p);\n div[0].style.margin = '5px 5px 5px auto';\n function displayTime() {\n p.text(new Date().toLocaleString('en-GB')); \n }\n toolbar.append(div);\n clockInterval = setInterval(displayTime, 1000);\n });\n</script>",
"storeOutMessages": false,
"fwdInMessages": false,
"resendOnRefresh": false,
"templateScope": "local",
"className": "",
"x": 550,
"y": 20,
"id": "41c445ea4ef57e61",
"type": "ui_chart",
"name": "trend",
"order": 4,
"width": "20",
"height": "6",
"label": "VOC level historical",
"legend": "false",
"nodata": "",
"dot": false,
"ymin": "0",
"ymax": "500",
"removeOlder": 1,
"removeOlderUnit": "86400",
"cutout": 0,
"useUTC": false,
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"className": "",
"x": 710,
"y": 340,
"id": "a6f9a157ec4aa242",
"type": "function",
"name": "chartformat",
"func": "//var data = [[{\"x\":1537348236000,\"y\":2493},{\"x\":1537348326000,\"y\":2493}]];\n//\nvar series = [\"VOC Gas Log\"];\nvar labels = [\"Labels\"];\nvar data = [];\n\nvar i, len, string;\n\nfor (i = 1, len = msg.payload.length, string = \"\"; i < len; i++) {\n data.push({ \"x\": Date.parse(msg.payload[i].timestamp) + 2 * 60 * 60, \"y\": Number(msg.payload[i].voc) });\n}\n\ndata = [data];\n\nmsg.payload = [{ series, data, labels }];\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 550,
"y": 360,
"41c445ea4ef57e61"
"id": "26933c4ce1586207",
"type": "ui_chart",
"order": 2,
"width": "2",
"height": "6",
"label": "PPM",
"chartType": "bar",
"legend": "false",
"interpolate": "linear",
"nodata": "",
"dot": false,
"ymin": "0",
"ymax": "500",
"removeOlder": 1,
"cutout": 0,
"useUTC": false,
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"className": "",
"x": 450,
"y": 180,
"id": "2c6cfd085b3f9f40",
"type": "ui_group",
"name": "Live gas monitor level",
"tab": "462952f9c42eb84e",
"order": 1,
"disp": true,
"width": "20",
"collapse": false,
"className": ""
"id": "500ed4569796efb2",
"type": "MySQLdatabase",
"host": "127.0.0.1",
"port": "3306",
"db": "GasMonitor",
"tz": "",
"charset": "UTF8"
"id": "68a6973f444db8dd",
"type": "ui_group",
"name": "Historical gas monitor level",
"order": 2,
"disp": true,
"width": "20",
"collapse": false,
"className": ""
"id": "462952f9c42eb84e",
"type": "ui_tab",
"name": "Home",
"icon": "dashboard",
"disabled": false,
"hidden": false
