No: NR-Dashboard V1
Ah- that is also possible in NR- even when I first discover this power-flow-card in HA- yes.
Look here: https://discourse.nodered.org/t/power-flow-card-again/87047/7?u=wp-rue
They look like a good option. The only missing link is a heat sensor unit
I have Aico detectors which are hardwired to each other (long time ago probably before they had a wireless option) - (sensors replaced since installation of course). I do have a couple of new units with the wireless as I didn't fancy ripping the place apart to install additional detectors.
Unfortunately Aico want over £200 for the gateway, and anyway it doesn't seem to have an interface I can use with NR (if anyone knows differently please let me know) It appears that they use 868MHz. I use rtl_433 but they do not have any Aico in the list of devices covered
Nearest neighbour is 1/2 mile away so I don't get a lot of extraneous signals. I use RTL_SDR & rtl_433 with a couple of dongles for the oil tank depth sensors & garden weather sensors. (rtl_433 outputs to MQTT so no problem getting the data into NR)
Aico do an input and output relays that connect to the interconnecting wire, you can connect these to smart devices to get alarms and start alarms if you want (model codes start EI128)
Thank you. I had not seen that
That kinda looks familiar to a dashboard-2 post I assisted on ![]()
I must point out I'm not on commission, but they do a full range of products.
There is a HA integration I believe, and I use the Python code from that to talk to NR.
But please do your own research, I don't want anyone blaming me if they burn to death ![]()
Looks like they brought out some Wi-Fi unit now as well.
No, but thank you for pointing them out, which I think is great.
Weird, the heat alarm on the X Sense website is not mentioned until you search for it, and then it comes up in euros.
When I have to replace my alarms in 10yrs time (if I'm still around
) I will be seriously considering these units ('cause all my alarms have to be interlinked). Good price too.
