Show html msg.payload on dashboard with template.node
I am trying to post a HTML code as msg.payload on a dashboard with a template.node
But the template.node doesn't post it as HTML text, but as plain text.
msg.payload looks like:
<b>07-03-2022 R1 Beta:</b><br>
Check van versienummer controleert op response 200 of 201, anders retun false <br>
<b>06-03-2022 R1 Beta:</b><br>
- Download flows.json wordt nu opgeslagen met versie naam <br>
<b>05-03-2022 R2 Beta:</b><br>
- Je kan nu per zigbee bridge een command sturen <br>
- Kleur/text verandert bij een beschikbare update <br>
In the template i put {{msg.payload}}
The text is visible, but not as HTML text, but it is shown as a text-block.
So i see the html commands, like <b>, </b> and <br>
How can i transfer the msg.payload, that it works like HTML and not as text-block?
You will need to show us your flow to understand what you are doing wrong.
Either use msg.template (have your html text in msg.template)and have the template node blank
Or
use a html tag with ng-bind <div ng-bind-html="msg.payload"></div> You can use any tag span, p, etc
great answer, a very big thanks.
The solution was the ng-bind. It works to which i was looking for
