Showing two icons on Worldmap
one of the trackers having device eui ending with 02 is facing issue in parsing through the buffer parser. Range issue don't understand why becoz both the trackers are in line of sight to the sky.
[{"id":"f1c3712a.51632","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"c573d354.4e202","type":"buffer-parser","z":"f1c3712a.51632","name":"Bulid Tags","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"byte","name":"lat","offset":6,"length":3,"offsetbit":0,"scale":1,"mask":""},{"type":"byte","name":"lon","offset":9,"length":3,"offsetbit":0,"scale":1,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":350,"y":160,"wires":[["bafbdd1c.dbce3"]]},{"id":"bafbdd1c.dbce3","type":"function","z":"f1c3712a.51632","name":"","func":"var lat = (msg.payload.lat[0] << 24)  + (msg.payload.lat[1] << 16) + (msg.payload.lat[2] << 8) \nvar lon = (msg.payload.lon[0] << 24)  + (msg.payload.lon[1] << 16) + (msg.payload.lon[2] << 8) \n\nif (lat > 0x7FFFFFFF) { \n  lat -= 0x100000000;\n}\n\nif (lon > 0x7FFFFFFF) {\n  lon -= 0x100000000;\n}\n\nlat /= 10000000; \nlon /= 10000000;\n\nmsg.payload.lat = lat ;\nmsg.payload.lon = lon ;\nmsg.payload.name = \"apple\"; //set name\nmsg.payload.icon = \"fa-truck\";  //set icon\nmsg.payload.marker = \"layer\"; //set marker\n\n//return msg.payload; WRONG - always return msg!\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":140,"wires":[["40ae8e7f.0cd12","dedad9e1.d48fb8"]]},{"id":"40ae8e7f.0cd12","type":"debug","z":"f1c3712a.51632","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":730,"y":80,"wires":[]},{"id":"56b1735a.72088c","type":"mqtt in","z":"f1c3712a.51632","name":"","topic":"bachloo.rahul@gmail.com/test","qos":"0","datatype":"json","broker":"55bef158.86a7c","x":120,"y":40,"wires":[["3b7b5746.9e7358"]]},{"id":"e9da35ff.a1ad48","type":"base64","z":"f1c3712a.51632","name":"","action":"","property":"payload","x":420,"y":80,"wires":[["c573d354.4e202"]]},{"id":"2290cb3c.d51354","type":"function","z":"f1c3712a.51632","name":"","func":"var t=msg.payload;\nmsg.payload=t.data;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":260,"y":100,"wires":[["e9da35ff.a1ad48"]]},{"id":"dedad9e1.d48fb8","type":"worldmap","z":"f1c3712a.51632","name":"","lat":"28.3917824","lon":"76.9599744","zoom":"10","layer":"OSM","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"true","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"none","showgrid":"false","path":"/worldmap","x":740,"y":160,"wires":[]},{"id":"3b7b5746.9e7358","type":"switch","z":"f1c3712a.51632","name":"","property":"payload.devEUI","propertyType":"msg","rules":[{"t":"eq","v":"20635f01d1000004","vt":"str"},{"t":"eq","v":"20635f01d1000002","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":110,"y":140,"wires":[["2290cb3c.d51354","6e345130.6a998"],["e996d627.23eab8","c399960d.750c38"]]},{"id":"cbe3233e.1dc17","type":"buffer-parser","z":"f1c3712a.51632","name":"Bulid Tags","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"byte","name":"lat","offset":6,"length":3,"offsetbit":0,"scale":1,"mask":""},{"type":"byte","name":"lon","offset":9,"length":3,"offsetbit":0,"scale":1,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":291,"y":256,"wires":[["5bcd89ac.eec178"]]},{"id":"5bcd89ac.eec178","type":"function","z":"f1c3712a.51632","name":"","func":"var lat = (msg.payload.lat[0] << 24)  + (msg.payload.lat[1] << 16) + (msg.payload.lat[2] << 8) \nvar lon = (msg.payload.lon[0] << 24)  + (msg.payload.lon[1] << 16) + (msg.payload.lon[2] << 8) \n\nif (lat > 0x7FFFFFFF) { \n  lat -= 0x100000000;\n}\n\nif (lon > 0x7FFFFFFF) {\n  lon -= 0x100000000;\n}\n\nlat /= 10000000; \nlon /= 10000000;\n\nmsg.payload.lat = lat ;\nmsg.payload.lon = lon ;\nmsg.payload.name = \"gps\"; //set name\nmsg.payload.icon = \"fa-truck\";  //set icon\nmsg.payload.marker = \"layer\"; //set marker\n\n//return msg.payload; WRONG - always return msg!\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":471,"y":236,"wires":[["a1dde264.4424","7af6dc66.00a194"]]},{"id":"a1dde264.4424","type":"debug","z":"f1c3712a.51632","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":651,"y":216,"wires":[]},{"id":"e996d627.23eab8","type":"function","z":"f1c3712a.51632","name":"","func":"var t=msg.payload;\nmsg.payload=t.data;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":191,"y":196,"wires":[["cbe3233e.1dc17"]]},{"id":"7af6dc66.00a194","type":"worldmap","z":"f1c3712a.51632","name":"","lat":"28.3917824","lon":"76.9599744","zoom":"10","layer":"OSM","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"true","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"none","showgrid":"false","path":"/worldmap","x":651,"y":296,"wires":[]},{"id":"c399960d.750c38","type":"debug","z":"f1c3712a.51632","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":110,"y":280,"wires":[]},{"id":"6e345130.6a998","type":"debug","z":"f1c3712a.51632","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":390,"y":40,"wires":[]},{"id":"55bef158.86a7c","type":"mqtt-broker","name":"","broker":"maqiatto.com","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
payload1
{"applicationID":"1","applicationName":"cloud","data":"A0hIggANEOxCLd8jBOVh8g==","devEUI":"20635f01d1000004","deviceName":"abeeway tracker2","fCnt":594,"fPort":18,"rxInfo":[{"altitude":0,"latitude":0,"loRaSNR":8.5,"longitude":0,"mac":"24e124fffef0a78e","name":"24e124fffef0a78e","rssi":-47,"time":"2020-11-17T11:58:23.441765Z"}],"time":"2020-11-17T11:58:23.441765Z","txInfo":{"adr":true,"codeRate":"4/5","dataRate":{"bandwidth":125,"modulation":"LORA","spreadFactor":7},"frequency":865402500}}
payload2
{"applicationID":"1","applicationName":"cloud","data":"A0hThwAJEOxGLd8jBsdI2w==","devEUI":"20635f01d1000002","deviceName":"abeeway tracker","fCnt":195,"fPort":18,"rxInfo":[{"altitude":0,"latitude":0,"loRaSNR":8.5,"longitude":0,"mac":"24e124fffef0a78e","name":"24e124fffef0a78e","rssi":-78,"time":"2020-11-17T11:56:39.509754Z"}],"time":"2020-11-17T11:56:39.509754Z","txInfo":{"adr":true,"codeRate":"4/5","dataRate":{"bandwidth":125,"modulation":"LORA","spreadFactor":7},"frequency":865402500}}
the error on the buffer parser has nothing to do with showing two icons.
Look at your flow - the original part from your other threads goes through a BASE64 node to convert the base64 into usable data.
you dont have one for the new nodes.
also, there is no need to duplicate the function or the buffer parser.
Simply set a property in the payload like "name" based on the result of your switch node.
e.g...
and disable the hard coded msg.payload.name = "apple" in your function
Can I please also ask again that you watch and re-watch this playlist: Node-RED Essentials until you "get it" - you will save yourself and us a whole lot of time.
change node is not adding payload.name property incase of both deveui 04 and 02.
[{"id":"f1c3712a.51632","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"c573d354.4e202","type":"buffer-parser","z":"f1c3712a.51632","name":"Bulid Tags","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"byte","name":"lat","offset":6,"length":3,"offsetbit":0,"scale":1,"mask":""},{"type":"byte","name":"lon","offset":9,"length":3,"offsetbit":0,"scale":1,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":570,"y":220,"wires":[["bafbdd1c.dbce3"]]},{"id":"bafbdd1c.dbce3","type":"function","z":"f1c3712a.51632","name":"","func":"var lat = (msg.payload.lat[0] << 24)  + (msg.payload.lat[1] << 16) + (msg.payload.lat[2] << 8) \nvar lon = (msg.payload.lon[0] << 24)  + (msg.payload.lon[1] << 16) + (msg.payload.lon[2] << 8) \n\nif (lat > 0x7FFFFFFF) { \n  lat -= 0x100000000;\n}\n\nif (lon > 0x7FFFFFFF) {\n  lon -= 0x100000000;\n}\n\nlat /= 10000000; \nlon /= 10000000;\n\nmsg.payload.lat = lat ;\nmsg.payload.lon = lon ;\n//msg.payload.name = \"apple\"; //set name\nmsg.payload.icon = \"fa-truck\";  //set icon\nmsg.payload.marker = \"layer\"; //set marker\n\n//return msg.payload; WRONG - always return msg!\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":660,"y":180,"wires":[["40ae8e7f.0cd12","dedad9e1.d48fb8"]]},{"id":"40ae8e7f.0cd12","type":"debug","z":"f1c3712a.51632","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":770,"y":100,"wires":[]},{"id":"56b1735a.72088c","type":"mqtt in","z":"f1c3712a.51632","name":"","topic":"bachloo.rahul@gmail.com/test","qos":"0","datatype":"json","broker":"55bef158.86a7c","x":160,"y":460,"wires":[[]]},{"id":"e9da35ff.a1ad48","type":"base64","z":"f1c3712a.51632","name":"","action":"","property":"payload","x":560,"y":100,"wires":[["c573d354.4e202"]]},{"id":"2290cb3c.d51354","type":"function","z":"f1c3712a.51632","name":"","func":"var t=msg.payload;\nmsg.payload=t.data;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":160,"wires":[["e9da35ff.a1ad48"]]},{"id":"dedad9e1.d48fb8","type":"worldmap","z":"f1c3712a.51632","name":"","lat":"28.3917824","lon":"76.9599744","zoom":"10","layer":"OSM","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"true","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"none","showgrid":"false","path":"/worldmap","x":740,"y":260,"wires":[]},{"id":"3b7b5746.9e7358","type":"switch","z":"f1c3712a.51632","name":"","property":"payload.devEUI","propertyType":"msg","rules":[{"t":"eq","v":"20635f01d1000004","vt":"str"},{"t":"eq","v":"20635f01d1000002","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":90,"y":160,"wires":[["cf9b9363.eb556"],["fedfe808.dd2e88"]]},{"id":"fedfe808.dd2e88","type":"change","z":"f1c3712a.51632","name":"msg.payload.name apple","rules":[{"t":"set","p":"payload.name","pt":"msg","to":"apple","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":220,"wires":[["2290cb3c.d51354"]]},{"id":"cf9b9363.eb556","type":"change","z":"f1c3712a.51632","name":"msg.payload.name pear","rules":[{"t":"set","p":"payload.name","pt":"msg","to":"pear","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":100,"wires":[["2290cb3c.d51354"]]},{"id":"7a8a6f07.e3c84","type":"inject","z":"f1c3712a.51632","name":"deveui 004","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"applicationID\":\"1\",\"applicationName\":\"cloud\",\"data\":\"A0hIggANEOxCLd8jBOVh8g==\",\"devEUI\":\"20635f01d1000004\",\"deviceName\":\"abeeway tracker2\",\"fCnt\":594,\"fPort\":18,\"rxInfo\":[{\"altitude\":0,\"latitude\":0,\"loRaSNR\":8.5,\"longitude\":0,\"mac\":\"24e124fffef0a78e\",\"name\":\"24e124fffef0a78e\",\"rssi\":-47,\"time\":\"2020-11-17T11:58:23.441765Z\"}],\"time\":\"2020-11-17T11:58:23.441765Z\",\"txInfo\":{\"adr\":true,\"codeRate\":\"4/5\",\"dataRate\":{\"bandwidth\":125,\"modulation\":\"LORA\",\"spreadFactor\":7},\"frequency\":865402500}}","payloadType":"json","x":100,"y":60,"wires":[["3b7b5746.9e7358"]]},{"id":"973aa0e2.a5e0d","type":"inject","z":"f1c3712a.51632","name":"deveui 002","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"applicationID\":\"1\",\"applicationName\":\"cloud\",\"data\":\"A0hThwAJEOxGLd8jBsdI2w==\",\"devEUI\":\"20635f01d1000002\",\"deviceName\":\"abeeway tracker\",\"fCnt\":195,\"fPort\":18,\"rxInfo\":[{\"altitude\":0,\"latitude\":0,\"loRaSNR\":8.5,\"longitude\":0,\"mac\":\"24e124fffef0a78e\",\"name\":\"24e124fffef0a78e\",\"rssi\":-78,\"time\":\"2020-11-17T11:56:39.509754Z\"}],\"time\":\"2020-11-17T11:56:39.509754Z\",\"txInfo\":{\"adr\":true,\"codeRate\":\"4/5\",\"dataRate\":{\"bandwidth\":125,\"modulation\":\"LORA\",\"spreadFactor\":7},\"frequency\":865402500}}","payloadType":"json","x":100,"y":280,"wires":[["3b7b5746.9e7358"]]},{"id":"55bef158.86a7c","type":"mqtt-broker","name":"","broker":"maqiatto.com","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
If you add debug nodes to the output of every node you will see payload.name gets lost after the first function node (because this function replaces msg.payload with msg.data)
please re-watch those videos.
please use debug nodes to see what is happening.
One possible fix is...
In the 2 change nodes, set msg.name instead of msg.payload.name
in the last function node, add msg.payload.name = msg.name;
If it doesn't work - add debug nodes to every node and see what is happening for yourself.
Thank you @steve i will definately watch the videos in the mean time you see this.
I removed the function where you lost the name parameter.
I think it will be easier to do operations with data where it is. msg.payload.data And then the output contains always everything.
[{"id":"c573d354.4e202","type":"buffer-parser","z":"f1c3712a.51632","name":"Bulid Tags","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"byte","name":"lat","offset":6,"length":3,"offsetbit":0,"scale":1,"mask":""},{"type":"byte","name":"lon","offset":9,"length":3,"offsetbit":0,"scale":1,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload.data","msgPropertyType":"","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":670,"y":160,"wires":[["bafbdd1c.dbce3"]]},{"id":"bafbdd1c.dbce3","type":"function","z":"f1c3712a.51632","name":"","func":"var lat = (msg.payload.data.lat[0] << 24)  + (msg.payload.data.lat[1] << 16) + (msg.payload.data.lat[2] << 8) \nvar lon = (msg.payload.data.lon[0] << 24)  + (msg.payload.data.lon[1] << 16) + (msg.payload.data.lon[2] << 8) \n\nif (lat > 0x7FFFFFFF) { \n  lat -= 0x100000000;\n}\n\nif (lon > 0x7FFFFFFF) {\n  lon -= 0x100000000;\n}\n\nlat /= 10000000; \nlon /= 10000000;\n\nmsg.payload.lat = lat ;\nmsg.payload.lon = lon ;\nmsg.payload.icon = \"fa-truck\";  //set icon\nmsg.payload.marker = \"layer\"; //set marker\n\n//cleanup things you don't want to see at the map tooltip\ndelete msg.payload.data\ndelete msg.payload.applicationID\ndelete msg.payload.applicationName\ndelete msg.payload.rxInfo\ndelete msg.payload.txInfo\n\n\n//return msg.payload; WRONG - always return msg!\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":820,"y":160,"wires":[["40ae8e7f.0cd12","dedad9e1.d48fb8"]]},{"id":"40ae8e7f.0cd12","type":"debug","z":"f1c3712a.51632","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":970,"y":140,"wires":[]},{"id":"56b1735a.72088c","type":"mqtt in","z":"f1c3712a.51632","name":"","topic":"bachloo.rahul@gmail.com/test","qos":"0","datatype":"json","broker":"55bef158.86a7c","x":160,"y":460,"wires":[[]]},{"id":"e9da35ff.a1ad48","type":"base64","z":"f1c3712a.51632","name":"","action":"","property":"payload.data","x":500,"y":160,"wires":[["c573d354.4e202"]]},{"id":"dedad9e1.d48fb8","type":"worldmap","z":"f1c3712a.51632","name":"","lat":"28.3917824","lon":"76.9599744","zoom":"10","layer":"OSM","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"true","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"none","showgrid":"false","path":"/worldmap","x":980,"y":180,"wires":[]},{"id":"3b7b5746.9e7358","type":"switch","z":"f1c3712a.51632","name":"","property":"payload.devEUI","propertyType":"msg","rules":[{"t":"eq","v":"20635f01d1000004","vt":"str"},{"t":"eq","v":"20635f01d1000002","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":90,"y":160,"wires":[["cf9b9363.eb556"],["fedfe808.dd2e88"]]},{"id":"fedfe808.dd2e88","type":"change","z":"f1c3712a.51632","name":"msg.payload.name apple","rules":[{"t":"set","p":"payload.name","pt":"msg","to":"apple","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":180,"wires":[["e9da35ff.a1ad48"]]},{"id":"cf9b9363.eb556","type":"change","z":"f1c3712a.51632","name":"msg.payload.name pear","rules":[{"t":"set","p":"payload.name","pt":"msg","to":"pear","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":140,"wires":[["e9da35ff.a1ad48"]]},{"id":"7a8a6f07.e3c84","type":"inject","z":"f1c3712a.51632","name":"deveui 004","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"applicationID\":\"1\",\"applicationName\":\"cloud\",\"data\":\"A0hIggANEOxCLd8jBOVh8g==\",\"devEUI\":\"20635f01d1000004\",\"deviceName\":\"abeeway tracker2\",\"fCnt\":594,\"fPort\":18,\"rxInfo\":[{\"altitude\":0,\"latitude\":0,\"loRaSNR\":8.5,\"longitude\":0,\"mac\":\"24e124fffef0a78e\",\"name\":\"24e124fffef0a78e\",\"rssi\":-47,\"time\":\"2020-11-17T11:58:23.441765Z\"}],\"time\":\"2020-11-17T11:58:23.441765Z\",\"txInfo\":{\"adr\":true,\"codeRate\":\"4/5\",\"dataRate\":{\"bandwidth\":125,\"modulation\":\"LORA\",\"spreadFactor\":7},\"frequency\":865402500}}","payloadType":"json","x":100,"y":60,"wires":[["3b7b5746.9e7358"]]},{"id":"973aa0e2.a5e0d","type":"inject","z":"f1c3712a.51632","name":"deveui 002","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"applicationID\":\"1\",\"applicationName\":\"cloud\",\"data\":\"A0hThwAJEOxGLd8jBsdI2w==\",\"devEUI\":\"20635f01d1000002\",\"deviceName\":\"abeeway tracker\",\"fCnt\":195,\"fPort\":18,\"rxInfo\":[{\"altitude\":0,\"latitude\":0,\"loRaSNR\":8.5,\"longitude\":0,\"mac\":\"24e124fffef0a78e\",\"name\":\"24e124fffef0a78e\",\"rssi\":-78,\"time\":\"2020-11-17T11:56:39.509754Z\"}],\"time\":\"2020-11-17T11:56:39.509754Z\",\"txInfo\":{\"adr\":true,\"codeRate\":\"4/5\",\"dataRate\":{\"bandwidth\":125,\"modulation\":\"LORA\",\"spreadFactor\":7},\"frequency\":865402500}}","payloadType":"json","x":100,"y":280,"wires":[["3b7b5746.9e7358"]]},{"id":"55bef158.86a7c","type":"mqtt-broker","name":"","broker":"maqiatto.com","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
