Simple Bar chart
Hello, I'm not a programmer and the question is so simple but I still couldn't find a solution.
I receive the data from DB SQLite in msg.payload and I intend to make a bar graph by date like the one in the picture, but I can't find how to do it.
Grafico
        "id": "e1e5f1cca22c6a02",
        "type": "tab",
        "label": "Flow 5",
        "disabled": false,
        "info": "",
        "env": []
        "id": "f951759994b5f009",
        "type": "ui_button",
        "z": "e1e5f1cca22c6a02",
        "name": "submit",
        "group": "f76629c8ef571e88",
        "order": 3,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "Submit",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "1",
        "payloadType": "str",
        "topic": "submit",
        "topicType": "str",
        "x": 270,
        "y": 440,
                "5d32cd0ff2bf47ff",
                "b87cf50ff46554a6"
        "id": "ece3f3d56fd87fab",
        "type": "ui_date_picker",
        "name": "start date",
        "label": "Start date",
        "order": 4,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "sdate",
        "topicType": "str",
        "className": "",
        "x": 500,
        "y": 220,
                "7fa43234aa77fe38"
        "id": "ba108cfbe760f2f3",
        "name": "End Date",
        "label": "End Date",
        "order": 5,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "edate",
        "topicType": "str",
        "className": "",
        "x": 500,
        "y": 280,
                "e542571b5ffaf4df"
        "id": "6652a6a0391d933e",
        "type": "ui_dropdown",
        "label": "Postos_Trabalho",
        "tooltip": "",
        "place": "Select option",
        "order": 2,
        "width": "6",
        "height": "1",
        "passthru": false,
        "multiple": false,
        "options": [
                "label": "Posto nº 1",
                "value": "Posto01",
                "type": "str"
                "label": "Posto nº 2",
                "value": "Posto02",
                "type": "str"
        "payload": "",
        "topic": "Postos",
        "topicType": "str",
        "className": "",
        "x": 470,
        "y": 160,
                "ad81551c98e7e607"
        "id": "5d32cd0ff2bf47ff",
        "type": "function",
        "func": "\nmsg={  \n    \n \"topic\":   \"SELECT  Data as x, SUM(Unid) as y FROM  \" +flow.get (\"Postos\")+ \" WHERE  Timestamp BETWEEN \" +flow.get (\"sdate\")+ \" AND \" +flow.get (\"edate\")+ \" GROUP BY Data\"\n    \n\n\n}\n\n\n\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 500,
        "y": 520,
                "8d94212a6a132791"
        "id": "7fa43234aa77fe38",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "sdate",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 720,
        "y": 220,
        "id": "e542571b5ffaf4df",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "edate",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 720,
        "y": 280,
        "id": "ad81551c98e7e607",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "Postos",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 720,
        "y": 160,
        "id": "8d94212a6a132791",
        "type": "sqlite",
        "mydb": "ed499a1a62c74337",
        "sqlquery": "msg.topic",
        "sql": "",
        "name": "Emp.DB",
        "x": 700,
        "y": 520,
                "6973bb8b35c582a4",
                "b8d5d9445675c0b1"
        "id": "b87cf50ff46554a6",
        "type": "function",
        "func": "\nmsg={  \n    \n  \"topic\": \"SELECT SUM(Unid) FROM \" +flow.get (\"Postos\")+ \" WHERE Timestamp BETWEEN \" +flow.get (\"sdate\")+ \" AND \" +flow.get (\"edate\")+\"\"\n\n\n}\n\n\n\n\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 500,
        "y": 400,
                "5b584265e8141ee7"
        "id": "5b584265e8141ee7",
        "type": "sqlite",
        "sql": "",
        "name": "Emp.DB",
        "x": 680,
        "y": 400,
                "365ed8a2bb3a50f1"
        "id": "1ddd8012aa218c72",
        "type": "ui_gauge",
        "order": 6,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "Total ",
        "label": "units",
        "format": "{{value}}",
        "min": 0,
        "max": 10,
        "colors": [
            "#00b500",
            "#00e60f",
            "#3acb52"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 1030,
        "y": 400,
        "id": "365ed8a2bb3a50f1",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload[0].SUM(Unid)",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 860,
        "y": 400,
                "1ddd8012aa218c72"
        "id": "ee1b8820b5479163",
        "type": "ui_chart",
        "order": 5,
        "width": 0,
        "height": 0,
        "label": "chart",
        "chartType": "bar",
        "legend": "false",
        "xformat": "D/M",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "86400",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 1270,
        "y": 480,
        "id": "6973bb8b35c582a4",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 930,
        "y": 640,
        "id": "b8d5d9445675c0b1",
        "type": "function",
        "func": "\n\n\nvar chart = [{\n \"series\": [msg.payload[0].x],\n\n \"data\": [msg.payload[0].y] ,\n  \"labels\": (\" \")\n  \n}];\n\n\nmsg.payload = chart;\n\n\n\n\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 940,
        "y": 540,
                "a6aaec32e767feec",
                "ee1b8820b5479163"
        "id": "a6aaec32e767feec",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1250,
        "y": 600,
        "id": "f76629c8ef571e88",
        "type": "ui_group",
        "name": "Group_ teste",
        "tab": "58cd2d9b8236774d",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "ed499a1a62c74337",
        "type": "sqlitedb",
        "db": "C:\\Users\\Admin\\Documents\\Emp.db",
        "mode": "RWC"
        "id": "58cd2d9b8236774d",
        "type": "ui_tab",
        "name": "Tab 4",
        "icon": "dashboard",
        "order": 4
Maybe this thread will help
Yessss. it works now ! Thank you for your help.
