Simple flow but not reliable
I created a flow which is triggered if a window is opened, after 5 minutes I want to have a reminder through an amazon echo that the window should be closed. If not closed within 2 minutes there should be a second message, every 2 minutes it should be checked if the window is still open and then fire the notification. If closed within the first 5 minutes or later the flow should be stopped.
When testing the flow works fine, but when set in action it fails in 80% of the cases. I get first notification but then the stoptimer for the next check after 2 minutes doesn't get enabled.
I can't find the failure, also it sometimes work as expected.
What am I missing?
[{"id":"e6b7e007.878fa8","type":"server-state-changed","z":"14d4946d.833e9c","name":"Badfenster lueften","server":"a68d7d60.2c7d7","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.window_aqa17","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":130,"y":120,"wires":[["29b63324.9d6c5c"]]},{"id":"29b63324.9d6c5c","type":"switch","z":"14d4946d.833e9c","name":"offen oder zu","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":120,"wires":[["f8e43b53.486478"],["d0e59c7f.19f158"]]},{"id":"86cbd389.dc9c5","type":"stoptimer","z":"14d4946d.833e9c","duration":"2","units":"Minute","payloadtype":"num","payloadval":"0","name":"Erinnerung 2 Minuten","x":680,"y":240,"wires":[["2ae88b9c.fca7d4"],[]]},{"id":"d0e59c7f.19f158","type":"change","z":"14d4946d.833e9c","name":"Timer STOP","rules":[{"t":"set","p":"payload","pt":"msg","to":"STOP","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":240,"wires":[["86cbd389.dc9c5"]]},{"id":"6ff6fb9b.c499ac","type":"api-current-state","z":"14d4946d.833e9c","name":"Status Badfenster","server":"a68d7d60.2c7d7","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"binary_sensor.window_aqa17","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":770,"y":120,"wires":[["8acc723f.c28548"],[]]},{"id":"8acc723f.c28548","type":"alexa-remote-routine","z":"14d4946d.833e9c","name":"Benachrichtigung EG","account":"6bcdcff1.67ded","routineNode":{"type":"speak","payload":{"type":"regular","text":{"type":"str","value":"Das Badfenster kann wieder geschlossen werden"},"devices":["8a5c53101475429dbcd9c02ceba2bcc4"]}},"x":1020,"y":120,"wires":[["86cbd389.dc9c5"]]},{"id":"2ae88b9c.fca7d4","type":"alexa-remote-routine","z":"14d4946d.833e9c","name":"Erinnerung EG","account":"6bcdcff1.67ded","routineNode":{"type":"speak","payload":{"type":"regular","text":{"type":"str","value":"Bitte das Badfenster schliessen"},"devices":["8a5c53101475429dbcd9c02ceba2bcc4"]}},"x":680,"y":400,"wires":[["86cbd389.dc9c5"]]},{"id":"f8e43b53.486478","type":"stoptimer","z":"14d4946d.833e9c","duration":"3","units":"Minute","payloadtype":"num","payloadval":"0","name":"5 min lueften","x":550,"y":120,"wires":[["6ff6fb9b.c499ac"],[]]},{"id":"a68d7d60.2c7d7","type":"server","name":"Home Assistant","addon":true},{"id":"6bcdcff1.67ded","type":"alexa-remote-account","name":"AlexaAmazon","authMethod":"proxy","proxyOwnIp":"192.168.178.48","proxyPort":"3456","cookieFile":"","refreshInterval":"3","alexaServiceHost":"layla.amazon.de","amazonPage":"amazon.de","acceptLanguage":"de-DE","userAgent":"","useWsMqtt":"on","autoInit":"on"}]
Welcome to the forum.
It seems that your flow only includes one node. You need to select all the relevant nodes and then Export.
Yes, new to the forum and new to Node Red :upside_down_face:
Thanks Colin.
Try something like this, not sure which phrase you want, so you may need to reverse them, the spoken words are set in trigger and change node.
[{"id":"57675e72.26a0d8","type":"tab","label":"Flow 6","disabled":false,"info":""},{"id":"918cdfc.bbfc5a","type":"function","z":"57675e72.26a0d8","name":"propagate","func":"let dimmers = [\"dimmer1\",\"dimmer2\",\"dimmer3\"];\nlet sender = msg.topic.split(\"/\")[2];\nfor(let i = 0; i < dimmers.length; i++ ){\n    if(dimmers[i] !== sender && !msg.payload.sender){\n        node.send({\"payload\":{\"bri\":msg.payload.bri, \"sender\": true},\n        topic:`cmnd/lighting/${dimmers[i]}/dimmer`});\n    }\n}\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":430,"y":140,"wires":[["c45dd6b4.1fce4"]]},{"id":"c444b383.2601a8","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stat/lighting/dimmer3/RESULT","payload":"{\"bri\":10,\"sender\":true}","payloadType":"json","x":190,"y":160,"wires":[["918cdfc.bbfc5a"]]},{"id":"d81e8ecc.765628","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stat/lighting/dimmer2/RESULT","payload":"{\"bri\":80}","payloadType":"json","x":200,"y":120,"wires":[["918cdfc.bbfc5a"]]},{"id":"d3c01d6e.c7aaf","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stat/lighting/dimmer1/RESULT","payload":"{\"bri\":40}","payloadType":"json","x":200,"y":80,"wires":[["918cdfc.bbfc5a"]]},{"id":"ae9a5160.f49ff","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stat/lighting/dimmer4/RESULT","payload":"{\"bri\":100}","payloadType":"json","x":80,"y":200,"wires":[[]]},{"id":"23aa6168.533326","type":"debug","z":"57675e72.26a0d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":140,"wires":[]},{"id":"c45dd6b4.1fce4","type":"delay","z":"57675e72.26a0d8","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":480,"y":200,"wires":[["71b4d027.1dd54"]]},{"id":"71b4d027.1dd54","type":"function","z":"57675e72.26a0d8","name":"simulate mqtt result","func":"const item = msg.topic.split(\"/\")[2];\nmsg.topic = `stat/lighting/${item}/RESULT`;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":690,"y":200,"wires":[["23aa6168.533326","918cdfc.bbfc5a"]]},{"id":"b8db2d9c.ebd32","type":"debug","z":"57675e72.26a0d8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":550,"y":600,"wires":[]},{"id":"4dc8f036.026c9","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmnd/lights/dimmer2/Dimmer","payload":"70","payloadType":"num","x":250,"y":280,"wires":[["2ff17866.86033"]]},{"id":"2ff17866.86033","type":"mqtt out","z":"57675e72.26a0d8","name":"","topic":"","qos":"","retain":"","broker":"e8ba3ef5.22f4a8","x":650,"y":360,"wires":[]},{"id":"4268b7a3.be459","type":"mqtt in","z":"57675e72.26a0d8","name":"","topic":"stat/lights/+/DIMMER","qos":"0","datatype":"json","broker":"e8ba3ef5.22f4a8","x":160,"y":360,"wires":[["3cb38782.b1b66","f46ba057.e03eb8"]]},{"id":"2a10f15b.f1cd2e","type":"function","z":"57675e72.26a0d8","name":"","func":"let dimmers = [\"dimmer1\",\"dimmer2\",\"dimmer3\"];\nlet sender = msg.topic.split(\"/\")[2];\nlet send = {};\nfor(let i = 0; i < dimmers.length; i++ ){\n    if(dimmers[i] !== sender && !msg.retain){\n        send = {\"payload\":Number(msg.payload), \"retain\": true,\n        topic:`cmnd/lights/${dimmers[i]}/Dimmer`}\n        node.send(send);\n    }\n    \n//send[i] = null;\n}\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":390,"y":360,"wires":[[]]},{"id":"3cb38782.b1b66","type":"delay","z":"57675e72.26a0d8","name":"","pauseType":"delay","timeout":"3000","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":270,"y":420,"wires":[["2a10f15b.f1cd2e"]]},{"id":"82294919.b120a","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmnd/lights/dimmer1/Dimmer","payload":"30","payloadType":"num","x":250,"y":240,"wires":[["2ff17866.86033"]]},{"id":"9c0025e9.86ffe8","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmnd/lights/dimmer3/Dimmer","payload":"0","payloadType":"num","x":240,"y":320,"wires":[["2ff17866.86033"]]},{"id":"f46ba057.e03eb8","type":"debug","z":"57675e72.26a0d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload & \" | \" & retained","statusType":"jsonata","x":490,"y":420,"wires":[]},{"id":"9d9cde6d.b99838","type":"mqtt in","z":"57675e72.26a0d8","name":"","topic":"cmnd/lights/+/Dimmer","qos":"2","datatype":"json","broker":"e8ba3ef5.22f4a8","x":190,"y":640,"wires":[["b8db2d9c.ebd32","1932f9a3.2d7cf6"]]},{"id":"294cb5d8.187b82","type":"mqtt out","z":"57675e72.26a0d8","name":"","topic":"","qos":"","retain":"","broker":"e8ba3ef5.22f4a8","x":570,"y":640,"wires":[]},{"id":"1932f9a3.2d7cf6","type":"function","z":"57675e72.26a0d8","name":"","func":"msg.topic = `stat/lights/${msg.topic.split(\"/\")[2]}/DIMMER`\n//msg.retain= true;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":420,"y":640,"wires":[["294cb5d8.187b82","b8db2d9c.ebd32"]]},{"id":"e92401aa.c1c7e","type":"inject","z":"57675e72.26a0d8","name":"100","props":[{"p":"payload.openPercent","v":"100","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":860,"wires":[["fdc0d58.4081c28"]]},{"id":"711aea43.2409bc","type":"inject","z":"57675e72.26a0d8","name":"0","props":[{"p":"payload.openPercent","v":"0","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":120,"y":920,"wires":[["fdc0d58.4081c28"]]},{"id":"5c0b832f.0ec19c","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"retain","v":"true","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stat/lights/dimmer3/DIMMER","payload":"0","payloadType":"num","x":380,"y":540,"wires":[["294cb5d8.187b82"]]},{"id":"fdc0d58.4081c28","type":"change","z":"57675e72.26a0d8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.openPercent > 0 ? true : false","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":880,"wires":[["b84dcbfc.816ad"]]},{"id":"b84dcbfc.816ad","type":"debug","z":"57675e72.26a0d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":580,"y":900,"wires":[]},{"id":"eb4e3876.e93928","type":"switch","z":"57675e72.26a0d8","name":"offen oder zu","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":330,"y":1100,"wires":[["7406465e.5e7f58"],["66f68d39.3792c4"]]},{"id":"66f68d39.3792c4","type":"change","z":"57675e72.26a0d8","name":"Timer STOP","rules":[{"t":"set","p":"reset","pt":"msg","to":"STOP","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":1160,"wires":[["583d59e1.86e28","7406465e.5e7f58"]]},{"id":"a049214f.b74cb","type":"alexa-remote-routine","z":"57675e72.26a0d8","name":"Benachrichtigung EG","account":"b0877f3.836aa","routineNode":{"type":"speak","payload":{"type":"regular","text":{"type":"msg","value":"payload"},"devices":["G090LF1182850C6D"]}},"x":1000,"y":1140,"wires":[[]]},{"id":"58e7c63a.e7634","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":170,"y":1080,"wires":[["eb4e3876.e93928"]]},{"id":"62274f0a.c715","type":"inject","z":"57675e72.26a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":160,"y":1140,"wires":[["eb4e3876.e93928"]]},{"id":"583d59e1.86e28","type":"trigger","z":"57675e72.26a0d8","name":"","op1":"Das Badfenster kann wieder geschlossen werden","op2":"","op1type":"str","op2type":"str","duration":"-120","extend":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":750,"y":1100,"wires":[["a049214f.b74cb"]]},{"id":"7406465e.5e7f58","type":"delay","z":"57675e72.26a0d8","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":520,"y":1060,"wires":[["583d59e1.86e28","30154867.5b77e"]]},{"id":"30154867.5b77e","type":"change","z":"57675e72.26a0d8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Bitte das Badfenster schliessen","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":1140,"wires":[["a049214f.b74cb"]]},{"id":"e8ba3ef5.22f4a8","type":"mqtt-broker","z":"","name":"testb","broker":"192.168.1.25","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"b0877f3.836aa","type":"alexa-remote-account","z":"","name":"alexaremote2","authMethod":"proxy","proxyOwnIp":"192.168.1.25","proxyPort":"3456","cookieFile":"alexa-remote2.txt","refreshInterval":"14","alexaServiceHost":"layla.amazon.co.uk","amazonPage":"amazon.co.uk","acceptLanguage":"en-UK","userAgent":"","useWsMqtt":"on","autoInit":"off"}]
Nice, it's working fine. I need to understand the differences to my setup and why mine wasn't working reliable.
Nikki
