how can I check several payloads in a single switch node?
Sample: i have a tradfri remote controller with 5 buttons. when i click the central button, then i get a value (empty), when i click top button (payload.stepmode 1 or 0) or left/right button (payload.value 1 or 0) then i get different payload-values.
This works, but i think, that is possible in 1x node and not 3 nodes:
if payload.stepmode = 0 then ..
if payload.stepmode = 1 then...
if payload.value = 257 then..
if payload.value = 256 then..
if payload = empty then ...
is this in 1 switch node possible or i need a function node? the flow in the screenshot is function, but i think, is not the right way...
I think you will either have to use multiple switch nodes or use a function node. However it may depend on what you want to do after deciding which conditions are satisfied. If you just need to set values for example it may be possible in a Change node, but if you need to head off down different flow paths then you need a Function or Change nodes I think.
