Hi, my farming neighbour requested a simple flood irrigation alarm to wake him at night so he can go redirect the water, no problem I thought. But I am having major trouble testing and resetting it with the dash interface. A manual inject on the flow editor works but doing the same through the dash buttons does not work. No doubt I am making a simple mistake, and obvious to a different set of eyes
watering%20alarm%20flow|690x348
[{"id":"fffd6f7e.5a893","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"4e4fa748.e09d28","type":"rpi-gpio out","z":"fffd6f7e.5a893","name":"Pin 12 Beacon light","pin":"12","set":true,"level":"0","freq":"","out":"out","x":970,"y":300,"wires":[]},{"id":"f6f50f25.47a3e","type":"exec","z":"fffd6f7e.5a893","command":"sudo shutdown -h now","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":700,"y":500,"wires":[[],[],[]]},{"id":"9788342c.ba0498","type":"ui_button","z":"fffd6f7e.5a893","name":"","group":"ab66c250.7caa","order":0,"width":0,"height":0,"passthru":false,"label":"Pi off","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":370,"y":500,"wires":[["f6f50f25.47a3e"]]},{"id":"93a49dd0.9c327","type":"ui_toast","z":"fffd6f7e.5a893","position":"top right","displayTime":"0.5","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"Water Alarm","name":"Water alarm activated","x":940,"y":180,"wires":[]},{"id":"a10e7066.149b3","type":"rpi-gpio in","z":"fffd6f7e.5a893","name":"","pin":"40","intype":"tri","debounce":"25","read":true,"x":150,"y":120,"wires":[["a01dde07.324c5"]]},{"id":"cf790043.5a58d","type":"inject","z":"fffd6f7e.5a893","name":"2 second flash","topic":"repeat","payload":"true","payloadType":"bool","repeat":"3","crontab":"","once":true,"onceDelay":0.1,"x":160,"y":280,"wires":[["163ee65c.b4254a"]]},{"id":"163ee65c.b4254a","type":"and-gate","z":"fffd6f7e.5a893","name":"","rules":[{"t":"true","propertyType":"msg","property":"payload","topic":""},{"t":"true","propertyType":"msg","property":"payload","topic":"repeat"}],"outputTopic":"","gateType":"and","emitOnlyIfTrue":true,"x":500,"y":260,"wires":[["c4981d8c.3edb1","62e54756.6e29b8"]]},{"id":"26844e68.65ea62","type":"inject","z":"fffd6f7e.5a893","name":"true","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":60,"wires":[["a01dde07.324c5"]]},{"id":"a01dde07.324c5","type":"change","z":"fffd6f7e.5a893","name":"binary to boolean","rules":[{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":120,"wires":[["76f3b9e8.588638"]]},{"id":"c4981d8c.3edb1","type":"change","z":"fffd6f7e.5a893","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"Water level detected","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":240,"wires":[["f2bd01f.6a92d","93a49dd0.9c327"]]},{"id":"f2bd01f.6a92d","type":"ui_audio","z":"fffd6f7e.5a893","name":"","group":"ab66c250.7caa","voice":"en-GB","always":true,"x":1000,"y":240,"wires":[]},{"id":"e41e7d3c.a6724","type":"ui_button","z":"fffd6f7e.5a893","name":"","group":"ab66c250.7caa","order":0,"width":0,"height":0,"passthru":true,"label":"Reset Alarm","tooltip":"","color":"red","bgcolor":"","icon":"","payload":"false","payloadType":"bool","topic":"","x":170,"y":360,"wires":[["163ee65c.b4254a","598ce2c9.af328c"]]},{"id":"62e54756.6e29b8","type":"change","z":"fffd6f7e.5a893","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":300,"wires":[["4e4fa748.e09d28"]]},{"id":"21d4f9f1.9846c6","type":"inject","z":"fffd6f7e.5a893","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":420,"wires":[["163ee65c.b4254a","598ce2c9.af328c"]]},{"id":"76f3b9e8.588638","type":"ui_button","z":"fffd6f7e.5a893","name":"","group":"ab66c250.7caa","order":0,"width":0,"height":0,"passthru":true,"label":"Test alarm","tooltip":"","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":150,"y":220,"wires":[["163ee65c.b4254a"]]},{"id":"598ce2c9.af328c","type":"debug","z":"fffd6f7e.5a893","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":550,"y":380,"wires":[]},{"id":"ab66c250.7caa","type":"ui_group","z":"","name":"Water alarm","tab":"2e2e199b.c2d2d6","disp":true,"width":"6","collapse":true},{"id":"2e2e199b.c2d2d6","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
