New thread:
See here.
Going on slightly from another thread with temperatures and alarms, it is interesting that I now have a similar question:
This flow works in that I have to press the button (start) 4 times to get an ACTION!
Pretty easy in retrospect to what @Andrei posted in the other thread.
Ok, so this works.
My quest is that it can also detect a single press.
I'll be thinking about it in the mean time, but I am just not getting something in how to let it do either a single or multiple presses.
[{"id":"9a9ece0e.e21968","type":"inject","z":"710ca09a.8302a8","name":"Start","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":490,"y":710,"wires":[["baa481f7.8c92f","d4d7fd43.e18b5"]]},{"id":"baa481f7.8c92f","type":"counter","z":"710ca09a.8302a8","name":"","init":"0","step":"1","lower":null,"upper":null,"mode":"increment","outputs":"1","x":676.6666870117188,"y":708.888916015625,"wires":[["18632614.5474e2","cdc2f3f7.8cd668"]]},{"id":"d4d7fd43.e18b5","type":"trigger","z":"710ca09a.8302a8","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"15","extend":false,"units":"s","reset":"","bytopic":"all","name":"","x":656.6666870117188,"y":768.888916015625,"wires":[["47f8333.7595f4c"]]},{"id":"18632614.5474e2","type":"debug","z":"710ca09a.8302a8","name":"RAW","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":816.6666870117188,"y":618.888916015625,"wires":[]},{"id":"cdc2f3f7.8cd668","type":"switch","z":"710ca09a.8302a8","name":"count presses","property":"count","propertyType":"msg","rules":[{"t":"eq","v":"4","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":846.6666870117188,"y":708.888916015625,"wires":[["b04381cc.95e9c"]]},{"id":"47f8333.7595f4c","type":"change","z":"710ca09a.8302a8","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"foo","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":816.6666870117188,"y":768.888916015625,"wires":[["b04381cc.95e9c","baa481f7.8c92f"]]},{"id":"b04381cc.95e9c","type":"trigger","z":"710ca09a.8302a8","op1":"","op2":"ACTION","op1type":"nul","op2type":"str","duration":"10","extend":false,"units":"s","reset":"","bytopic":"all","name":"","x":1066.6666870117188,"y":708.888916015625,"wires":[["6419695d.f444a8"]]},{"id":"46bb072c.9ab548","type":"inject","z":"710ca09a.8302a8","name":"Reset","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"0.5","x":656.6666870117188,"y":818.888916015625,"wires":[["47f8333.7595f4c"]]},{"id":"6419695d.f444a8","type":"debug","z":"710ca09a.8302a8","name":"ACTION!","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1226.6666870117188,"y":708.888916015625,"wires":[]}]
