I've made this flow to handle the single-press and press-and-hold for a button on my Home Assistant.
The zigbee button only gives press and release.
I was wondering if there were a better way, than using a flow variable? It seems clumsy ![]()
Have a look here which descibes how to make a momentary button, ie like your Press and Hold. It works both with mouse and touchscreens.
I might be wrong but that seems to be a dashboard button, whereas @fribse has a physical button and already gets a "button down" and a "button up" message.
I looked at this earlier but didn't reply because it's Home Assistant related, which might change things.
On the face of it though:
Button down : start motor
Button up: stop motor.
Can you explain why this is not enough?
Agh quite so.
