Momentary switch or button (normally open)
Hi, first time poster and newbie. :crazy_face:
I've been searching all over for a way to put a momentary button on my node red dashboard. Something that goes high while pressed and back to low when left go. I didn't find anything like that in the library here.
Anyone know of such a thing?
Thanks in advance,
Bob
There is no such node to install that would give you the momentary button functionality. But it can be done by using the ui_template node.
Have you searched here in forum? There is many threads talking about the momentary button. Many examples given and discussed.
Do you need the 'let go'message to happen when the button is released or would it be ok for it to happen a defined time after the pressed message? If the latter then you can use a ui_button followed by a Trigger node to send the On then Off messages.
I need something to turn on only when the button is pressed/held down and turn off when the button is left go of.
Was hoping for an easy solution as I don't have a lot of experience yet on writing code. I have been going thru the forum, maybe I'll find something here yet that I can work with.
Thanks,
Bob
OK. Play with this.
[{"id":"eac5d9eb.958798","type":"ui_template","z":"6d08d5ab.a8aa3c","group":"61e6d4c4.e7619c","name":"momentary button","order":7,"width":"1","height":"1","format":"<div id=\"momentary\">\n   <md-button style=\"min-width:36px;\n                    width: 100%; \n                    height: 100%; \n                    margin:0; \n                    padding: 0px; \n                    border-radius: 50%; \n                    background-color:green\">\n       \n      <i class=\"fa fa-hand-pointer-o\"></i>\n   </md-button>\n</div>\n<script>\n(function($scope) {\n    \n$('#momentary').on('touchstart mousedown', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"topic\":\"momentary\",\"payload\": true});\n});\n\n$('#momentary').on('touchend mouseup', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"topic\":\"momentary\",\"payload\": false});\n});\n    \n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":360,"y":140,"wires":[["534f375d.fce978"]]},{"id":"534f375d.fce978","type":"debug","z":"6d08d5ab.a8aa3c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":530,"y":140,"wires":[]},{"id":"61e6d4c4.e7619c","type":"ui_group","name":"TEST","tab":"d680797a.2f8b88","order":1,"disp":true,"width":"5","collapse":false},{"id":"d680797a.2f8b88","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Thank you!! That's something I can work with. :+1: Seems to operate just like I need.
Bob
Of course it does :slight_smile: But you just missed the learning part.
Well I still have to make it work for my needs so some learning yet. :wink: It has to control gpio pins on an esp8266 that is mqtt'd to a raspberry pi broker. I'm getting there little by little...
Bob
